Four Litre
posted on 21/1/12 at 09:20 PM |
Type 9 Gearbox Extender - stiff change
Hi all
I've finally got around to stripping the interior and in the process adding a tiger gearbox remote extende to the avon. All seems to be ok,
however it now seems very hard to get into reverse and 5th gear. when I say stiff it gone from smooth as silk to a proper gym workout getting reverse
and a grit your teeth fight to get it into 5th. 1st, 2nd, 3rd and 4th are fine.
Is this normal and to be expected , appreciate its not likely to improve the link, I've thrown on loads of grease but it doesnt seem to make a
difference?
Any ideas?
pjay
posted on 21/1/12 at 11:17 PM |
Fitted the Tiger remote to my S6 - not the finest piece of engineering.
I needed to quite a bit of adjustment to get it just right - this included opening up some of the mounting holes IIRC. Overall shouldn't be
tight on the gear selections.
I'd say loosen the three mounting bolts and try a few different positions to see if it improves.
jollygreengiant
posted on 22/1/12 at 07:34 AM |
![](/images//smilies/shocked.gif) ![](/images//smilies/wink.gif)
pjay
posted on 22/1/12 at 08:16 AM |
Steady!
laptoprob
posted on 22/1/12 at 09:16 AM |
+1
Tigers remote is pants to say the least. I had one and rang to complain, they said there was a batch that was made badly and to send it back for an
exchange. I did and the next one was as bad!!
I bought a very good one from (dare i say it ) GTS Tuning.
But basically its the same the one most people sell and also the ones on ebay.
Try MAC#1 on 01142511016.
[Edited on 22/1/12 by laptoprob]
http://www.youtube.com/watch?v=ajlF4nWJtGA
Four Litre
posted on 22/1/12 at 05:47 PM |
Ok thanks all - well first I will try the alignment, then if not its going back to tiger..
perksy
posted on 22/1/12 at 05:54 PM |
*If* its similar to the Westfied one sometimes it's necessary to put either one or two plain washers under the monting holes
This seems to sort any alignment issues
