Paul (Notts)
posted on 26/3/12 at 08:15 PM |
919 blade clocks
919 blade clocks.
After a set of clocks for a 919 blade engine. Don’t know much about motor bike engines and there seem to be a few variations. So any advice
welcome.
Paul
mark chandler
posted on 26/3/12 at 08:35 PM |
Make sure you get the bit of harness to go with them !
I got some 919 all in one clocks, pig to attach wires to the little pins but they work well.
![](/galpreviews/a489645-clocks_hall.JPG) ![Rescued attachment clocks_hall.JPG](/gallery/a489645-clocks_hall.JPG) Rescued attachment clocks_hall.JPG
9 boltheads on the prop gets you very close to correct speed on the mph clock with 3.65 diff and 185/60/13 tyres, this was just using a scrap ABS
sensor from the sierra.
I cut a hole to recess the clocks in my panel, I could/should have split them (they screw together) then cut a hole smaller and sandwiched the ali
dash panel.
Regards Mark
