Author: Subject: 5 point harnesses
medic_dan
posted on 26/4/12 at 07:06 PM Reply With Quote
5 point harnesses
Has anyone used 5 point harnesses? If so do you need seats with a slot for the crutch strap or can they be used with the more standard seats?
Dan
HowardB
posted on 26/4/12 at 08:17 PM Reply With Quote
may I suggest that in addition to the wisdom of the collective that you read this excellent guide
It is the definitive article
hth
Howard
medic_dan
posted on 26/4/12 at 09:59 PM Reply With Quote
hth
Thanks Howard
Stott
posted on 27/4/12 at 08:37 AM Reply With Quote
hth
Thanks Howard
The only problem with that is if you fit your belts as per the guide so they fit your torso then its likely the shoulder mounts will fail iva for being too low.
You'll have to space them up then take the spacers out after the test as the vosa test stick thingy is hopeless and puts my belts at a downward angle from the mounting to my shoulders.
Hth
Stott
