mad4x4
| posted on 11/5/12 at 07:50 AM |
Compressor 12v with Shutoff
Looking for a 12v version of
Linky
Doesn't need a large tank on it but does need to be able to cutoff at W.P. (working pressure) of around 90 psi so that it is no continously
running.
Scot's do it better in Kilts.
rallyingden
| posted on 11/5/12 at 08:03 AM |
How about running it via an inverter?
RD
owelly
| posted on 11/5/12 at 08:07 AM |
http://mobile.maplin.co.uk/module.aspx?moduleno=225095
And a normal pressure switch...?
http://www.ppcmag.co.uk
mad4x4
| posted on 11/5/12 at 01:32 PM |
Yes ok source me a pressure switch most i can find are 240v
Air Compressor Pressure Switch Control Valve 90-120 PSI | eBay
owelly
| posted on 11/5/12 at 01:45 PM |
And? Just use a 240volt one.
| posted on 11/5/12 at 05:13 PM |
If it will switch 240v it will switch 12v, what's the problem. The switch works on the air pressure not the voltage.
