TimC
| posted on 17/8/12 at 09:47 PM |
Landy Peeps - advice please
We're moving at the end of the month to a house down a steep forestry track. We're probably going to need two 4x4s and one will have to
be fairly serious for winter.
Can I please get folks' thoughts on this - eBay Item
Its local, presumably dirt cheap to insure and, well, appears pretty cheap & charming to me - vile seat covers aside!
owelly
| posted on 17/8/12 at 09:58 PM |
My main concern would be the incorrect registration! I'm sure it hasn't kept enough DVLA points to retain the original 1974 V5.
http://www.ppcmag.co.uk
Wheels244
| posted on 17/8/12 at 10:44 PM |
Hi Tim
If you know your way around this sort of thing - I think you'd be ok with it - it's not too expensive.
I would consider Owelly's point - although the current owner doesn't seem to have any problems with insuring it - at least it's not
one trying to be passed off as tax exempt as is often the case with this sort of thing.
I had a hybrid years ago, but it was a coil converted 2a chassis - nice V8 in it
For not too much more money though, you could be into a 90\Defender.
Rob
Doctor Derek Doctors
| posted on 17/8/12 at 10:57 PM |
The Defender body on a Rangey chassis is a petty standard Hybrid. We built a couple and they both had enough points to satisfy the man from the
government
You'd be better off just buying an old Range Rover though, it will have all the off-road ability without the hideously cramped and uncomfortable
interior, get a manual V8 on LPG and it will cost you less to run that a TDi as well.... I just sold one for £700....
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
TimC
| posted on 17/8/12 at 11:09 PM |
quote: Originally posted by Wheels244
Hi Tim
For not too much more money though, you could be into a 90Defender.
Rob
Ah Rob, I was hoping you'd be around to give me your view. Putting aside the registration thing for a moment, what would be the advantage of a
90 over this thing? I'm sure I've read about the 100 being ideal? I've not seen too many Landies at this price point without
impending rust issues!
Callan, I take your point but the Landy body is pretty cool.
Wheels244
| posted on 17/8/12 at 11:40 PM |
Hi Tim
Rob
Tim
There wouldn't be any great advantage other than if you went down the 90\Defender route you'd be getting something relatively
'standard'.
The one on eBay is put together from bits which isn't necessarily a bad thing as you would hope any faults would have been rectified in the
build.
I'm not sure it's a Defender body, could be a Series body with 90 wings and bonnet - the dashboard is definately out of a Series - not a
show stopper, just a bit more old fashioned.
100" is considered the best wheelbase for offroading.
A 1987 'E' plate with a 200tdi conversion went for around £2k one of the Landrover Forums I go on - it was tidy too with 12mths MOT.
Doctor has got a point about an old Range Rover or Disco - but as I'm sure you're aware you'll have to be handy with the welder.
I'm a sucker for non standard things - if it's close, I'd go for a look.
[Edited on 17/8/12 by Wheels244]
| posted on 17/8/12 at 11:45 PM |
Hi Tim
Rob
Well I can only let you learn the hard way...... everytime you smash you knee getting in, everytime you crack your elbow on the door when you go over
a bump, every time you get cramp because you can't adjust the seat you will curse the day you didn't get a Range Rover. My first two cars
were Landy's and the amount of time I finished a journey by slamming the door as I got out clutching a bashed limb while swearing at it through
gritted teeth was suprisingly high.... its called "Land Rover Elbow" for a reason.
www.t89.co.uk
callan@t89.co.uk
Wheels244
| posted on 17/8/12 at 11:53 PM |
Hi Tim
Rob
Great fun though - I love mine, can't ever see me getting rid of it
| posted on 18/8/12 at 12:22 AM |
Woah! I never said I didn't love them. I loved my old Lightweight. its just that I soon came to apppreciate that while it looked cool a Range
Rover or Disco was just as good (usually better) off-road and offered a level of comfort that was acceptable to someone born anytime after the 12th
century AD
We stopped building Hybrids like the one in the Ad' because we realised that we were just making something worse than the standard Range Rovers
we were starting with. Bobtails, thats the answer!
www.t89.co.uk
callan@t89.co.uk
mad4x4
| posted on 18/8/12 at 09:23 AM |
I would avoid HYBRID landrovers unless it is original part from an engine change.. .... Fist impressions - BINGER!
Just looks wrong. If it's 100 Inch then how did he get a 90" body to fit ? if it has a ranger tover chassis and is 1974 then why is
it registered as a DEFENDER which only star production in Early 80's
If police check that on a motorway and get VOSA involved you be in for trouble.....
Should have been SVA'd IVA'd unless you can prove it was built before the SVA and then it would have been sorted in the ammnesty....!
Guess BUYER BEWARE!
Scot's do it better in Kilts.
wilkingj
| posted on 18/8/12 at 09:27 AM |
Thats a series 3 Windscreen wiper set up as well (middle to centre wipe is S2 and S3, not 90/110 which is parrallel wipe). Hence I would suspect a S3
bulkhead, ie OLD (pre 1983), and therefore possibly another rust issue.
The Dash is definately S3. The only thing there thats a 90/110 could be just the wings or perhaps just only the plastic eyebrows.
Its got Sliding windows on the doors which is a S2/3, and not a 90/110/defender, as they had wind up windows all except for a very very few 1983
110's (pre-facelift model), Army windows are sliding, but have sloping glass not a straight vertical split like this one)
I would say some of this is a Series body on a rangey chasis, and the bloke has it shown as a Defender under the TYPE in the Advert, hence IMHO
misrepresented. Namely its a S3 bulkhead, S3 doors to start with. It could be a cut down 110 rear tub and front wnings and bonnet. I cant tell from
the pictures.
It looks a real Bitza. However, that is not usually a major issue for a Landy.
Bear in mind that some insurance companies will not like it. You will need to make a full declaration, or you could end up uninsured. Namely its all
OK, until you have an accident and a sharp eyed insurance assessor spots its not standard, and that would not be hard to do. Leaving you with no
vehicle and no or a reduced payout.
National Farmers Union were very good for a Landy insurance when I had mine. But mine was a std one.
A 1974 chassis will have tinworm somewhere. Check thoroughly, I take a thin screwdriver and test with that... watchout as a lot of owners dont like
that sort of testing!
I would also check the chassis and engine numbers, against the VIN plate, and especially against the V5.
A TDi300 is a nice engine, the R380 gearbox is the best one to have. Expect 26mpg as an average. I have yet to meet a diesel landy that does 30mpg, as
an average. Possibly on a run at 50mpg. They have the aerodynamics of a brick.
I would not buy that vehicle without a very close and detailed inspection by someone who really knows both Landies and Rangeys in depth.
ie someone who strips and builds them, not someone who just drives them.
Done a Vehicle check on the reg to see what its says?
IHMO its a Range Rover Van or Truck, or Van with Windows. Thats what I would expect to see on the V5.
I would bet that the V5 still says just plain Range Rover.
Just be very careful on this one. It could be good... But I would want ALL the paperwork completely straight / correct and in order before I parted
with any money.
Just my 2d's worth.
EDIT:
Oh dear, just saw this in the questions...
" though off the top of my head it's registered as a 109 Land Rover,"
If its a Landy reg with a rangey chassis its an automatic Q plate.
ie the chassis has been replaced with a non identical chassis, and its almost guaranteed to be secondhand chassis.
Thus a secondhand chassis on a vehicle is an Automatic Q plate.
Li
nky
Rangey Registration AND Rangey Chassis, should be OK, if done correctly. Landy Registration and a Rangey Chassis, is a BIG CAN OF WORMS!
At this point I would just walk away!
[Edited on 18/8/2012 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
TimC
| posted on 18/8/12 at 09:52 AM |
Thanks Gents. I can't help wondering if the non-original chassis would really make any material difference to the safety and/or structural
integrity of a vehicle like this but I suppose rules is rules.
Hmm.
wilkingj
| posted on 18/8/12 at 10:02 AM |
Hmm.
This is more about the identity of the vehicle and the paperwork being correct, or namely NOT buying yourself a world of administrative hurt.
There are lots of hybrids about, and the chassis strength shouldnt be an issue. Rangey chassis are just as good as Landy ones. As long as thay are NOT
RUSTY. Thats a 38 year old chassis, expect some rust!
The bloke does not seem to even know whats on the log book.
To me...that sets the alarm bells ringing. I know exactly what all the vehicles I had were and what was on the log book (at the time I owned them!)
Ask youself the same question... What is the car I drive, and what does it say on the V5? If you dont know that... it says a lot about the person
selling it.
All I am saying is just be very careful if you decide to go ahead.
If you really want a Landy, then you will probably look at 10+ before finding a really good one. DO NOT BUY UNSEEN!!!!!!
If its just a 4x4 to get up a muddy track in winter, then think of a Suzuki, a Lada Niva / Cossack, or a Toyota pickup truck (4x4 version)
All of those tend to be a lot more reliable and less mucked about. They are all just as capable. I have seen a Suzuki SJ climb slippery slopes that a
fully tricked out Landy could not make. It impressed me! Toyota are relaible and sturdy ie look at what top gear did to one!
Hope this helps..
Best Regards
Geoff
TimC
| posted on 18/8/12 at 10:23 AM |
Cheers. Not that it should necessarily make a difference, but the 'bloke' appears to be a young student/graduate who answers to Susie.
[Edited on 18/8/12 by TimC]
Wheels244
| posted on 18/8/12 at 10:26 AM |
This is one of the REALLY dodgy ones
Land Rover Series 2/Defender 3.5 V8 Hybrid Tax Exempt | eBay
Not much left of the 1966 vehicle on this one
mad4x4
| posted on 18/8/12 at 10:28 AM |
Could you live with this if the mods have not been done properly......
Landrvoer man myself , but I sold my hybrid for spares after this story....>!
Wheels244
| posted on 18/8/12 at 10:30 AM |
This doesn't look as though it was made in 1968 either !!
land rover 88' defender tax exempt 90 hybrid galvanised chassis red | eBay
tomgregory2000
| posted on 18/8/12 at 10:43 AM |
That's a series rear crossmember, I would steer clear of that
mark chandler
| posted on 18/8/12 at 12:03 PM |
The only difference between a landrover not getting stuck in mud and a range rover/discovery being stuck is tyres.
The problem with range rover/discoveries is rust, not so much chassis rust as body rust on mounting points hence plenty of hybrids out there, some are
mine !
If I was buying a car for this money to use then a late classic range rover is a good bet, high levels of comfort just shove some aggresive tyres on
for the winter.
Regards Mark
[Edited on 18/8/12 by mark chandler]
TimC
| posted on 18/8/12 at 04:54 PM |
That is pretty chilling. Whether or not you should therefore view modified vehicles en masse differently is perhaps a point for debate. Do you not fly
because planes have had failures?
I have to admit that I"m struggling with this. In many ways the hybrid in question seems to make a lot of sense. In other ways it seems like a
bad idea. Ii'll have a chat with my local expert tonight and perhaps take him to look at it.
John Bonnett
| posted on 18/8/12 at 08:09 PM |
I wonder if the DVLA ever trawl through these "Tax Exempt" adverts.
I noticed this one the other day
LANDROVER 2A 1966 TAX EXEMPT | eBay
and that was pulled very soon after it was posted and it struck me then that he could have had a "Visit"!
It will be interesting to see if the other two highlighted will suffer a similar fate.
As it happens, I've just bought a '59 Land Rover to replace my Hilux which sadly failed its MOT.
[Edited on 18/8/12 by John Bonnett]
MK9R
| posted on 18/8/12 at 10:50 PM |
If you want a cheap landy try and early freelander with then old L series diesel. As long as its got the transmission in 1 piece and youask the right
people for advice it will do everything you need. With the right yres on they are good off roaders, but will still reurn good mpg on road and a lot
easier and less tiering to drive than a disco or defneder.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
TimC
| posted on 19/8/12 at 12:42 PM |
The verdict:
Went to see the Landy today with a guy who really knows his onions. Its not for me.
Liked:
300 Tdi engine - plenty of power, ran well although a bit of blue smoke on over-run
R380 gearbox was really really sweet - very car like
Range chassis seemed to be highly competent in general
Disliked:
Leaking brakes (x2)
Leaking power steering
Horrendous wiring
Loose a frame
Needs a total rebuild really
Ho-hum.
TimC
| posted on 19/8/12 at 12:52 PM |
There's always this French Blue Niva
http://classifieds.pistonheads.com/classifieds/used-cars/lada/niva/lada-niva-4x4-1-7-lhd-2005/334280
mad4x4
| posted on 19/8/12 at 01:42 PM |
Now then being Russian built they are like tanks!
