PSpirine
| posted on 19/9/12 at 09:50 PM |
Anyone run a garage near Manchester? Need a car fixed!
One of my mates has just said her Corsa (2004)'s gearbox has gone:
Details (quoted):
Gearstick got stuck in neutral and wouldn't move or engage gear.
After a bit went in and car drove but gears don't feel right.
To me sounds like a clutch adjustment or hydraulic fault (don't know whether it's cable or hydraulic!).
If somebody local (she's in Hulme) could have a look to better diagnose and hopefully fix it assuming it's not terminal, it'd be
much appreciated as she's not exactly a car person and I wouldn't want a dealer to rip her off.
PM me contact details and I'll pass them on to her so she can get in touch direct and explain it a bit better!
Muchly ta,
Pavel
PSpirine
| posted on 19/9/12 at 09:54 PM |
Update:
"gears are crunchy and difficult to select"
Sounds even more like clutch actuation to me...
| posted on 19/9/12 at 10:01 PM |
Check the gear linkage before condemming the box. They suffer with broken linkages . Easy to fit if you can get under the car to get at the linkage
pinch bolt.
omega 24 v6
| posted on 19/9/12 at 10:31 PM |
There is a plastic ball joint rod ( joints at both ends) which are notorious for wearing/jumping off. If its that its a 5 seconds fix ( really is) to
clip it back on. The wire it or tie wrap it in place and it'll last for a long time yet.
ETA you can see it over the back of the gearbox at the bulkhead area looking in with the bonnet open> no need to crawl under for this one. ( If
thats what it is)
[Edited on 19/9/12 by omega 24 v6]
PSpirine
| posted on 19/9/12 at 10:38 PM |
Thanks both, I don't think the linkage is broken if it "fixed itself", but if they wear out that could be it! or the clutch
isn't disengaging properly..
I'd pop over and have a look myself but I'm 100 miles away this week..
Pavel
omega 24 v6
| posted on 19/9/12 at 10:40 PM |
My son in laws one had the problem I described. He could still get gears but it didn't " feel right".
matt_gsxr
| posted on 19/9/12 at 11:28 PM |
adithorp is based around that area and is good
Slimy38
| posted on 20/9/12 at 05:14 AM |
That failed on my brother in laws Astra, but he'd had trouble selecting gears for ages. He'd just put it down to a typical
'vague' gear select. When it finally did break we couldn't even tie wrap it back together and had to buy a new one, about £20 I
think? His first comment was 'wow, the gearbox feels good!'.
| posted on 20/9/12 at 06:48 AM |
Other thing it could be is low gearbox oil level, mainshaft needle roller bearings over heat and bind
adithorp
| posted on 20/9/12 at 07:25 AM |
U2U sent
For what it's worth, first thought was linkage but from later description it's most likely a release bearing or clutch finger
failure...
Linkage failure invariably includes the words "it's gone all floppy" in the description.
[Edited on 20/9/12 by adithorp]
http://jpsc.org.uk/forum/
marcjagman
| posted on 20/9/12 at 08:39 AM |
Put the car in gear with engine of, push clutch pedal down and hold it, start car, if the car moves it's a clutch problem, if it doesn't
then it's something else.
adithorp
| posted on 20/9/12 at 02:29 PM |
Well... The fluid in the brake resevoir was below the take off of the clutch master and it run out through the bottom of the bell-housing as quick as
we can top it up. Looks like the concentric slave has gone. we won't know the full story untill the 'box is off.
PSpirine
| posted on 20/9/12 at 02:30 PM |
Thanks everyone for your help
*warm fuzzy loving LocostBuilders feeling*
