clairetoo
| posted on 6/10/12 at 08:11 AM |
MOT question
I'm just checking over my Mx5 before this mornings MOT - and now have a question
There is no fog lamp fitted , allthough there is a foglamp switch ?
Further investigation shows the high level brake light has been re-wired as a fog lamp , with an extra switch (which illuminates when the light is on)
It only works with the lights and ignition on , so appears to be wired correctly .
Thing is - is this OK ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
| posted on 6/10/12 at 08:27 AM |
The position of the light is tested as well so if it's in the middle or to the right it should be o.k. Does the switch have appropriate markings
or a label ?
Macbeast
| posted on 6/10/12 at 09:02 AM |
I don't think a lamp at high level would pass. It certainly wouldn't pass IVA
Min height 250
Max height 1000
[Edited on 6/10/12 by Macbeast]
Mark Allanson
| posted on 6/10/12 at 09:13 AM |
he hi level brake lamp if fitted must work as a hi level brake lamp, which it wont.
Universal foglamps are a tenner and will take 30 mins to fit and wire.
clairetoo
| posted on 6/10/12 at 09:18 AM |
Min height 250
Max height 1000
I checked the MOT manual , and theres nothing about height in there - but it is OK as it is just 850mm to the center .
Theres no label or markings on the switch - I'll just write on a bit of masking tape for now , but I am thinking I should re-wire it through the
Mazda switch (and maybe fit a proper fog light , maybe to cover the redundant exhaust cutout in the bumper )
Claire xx
| posted on 6/10/12 at 09:39 AM |
Might pay to point the switch out to the tester, If he finds the normal fog lamp switch doesn't work he won't waste any time looking for
another one?
mtechmatt
| posted on 6/10/12 at 10:18 AM |
I would fail it...
A high level brake light must act as that...
Unless permanently disconnected... (as per the manual...)
Matt (I dont do much testing anymore, but I think thats right!)
V4 Engine Management System | Online Shop |
Rolling Road Tuning | Motorsport
Preparation | Engine Packages | Throttle
Bodies
Check out what's happening in the workshop via our Facebook Page:
The Workshop
MEGASQUIRT ROLLING ROAD & BIKE CARB TUNING SPECIALISTS
www.mtechautomotive.co.uk
clairetoo
| posted on 6/10/12 at 11:03 AM |
It passed on the fog light (switch was no problem , since I sat in it for most of the test !) but...........it failed on a badly leaking rear shock -
that was fine before setting off for the test
Anyone got a rear shock for a Mk1 Mx5 they dont need.........................
Claire xx
| posted on 6/10/12 at 12:07 PM |
Whatever shock you buy I would suggest don't buy KYB ---- I have just replaced one after less than a year.
