mookaloid
| posted on 27/10/12 at 11:10 PM |
Tintop disc skimming
My tintop will be due it's MOT soon and all 4 brake discs are getting a fair band of corrosion on them. The car only gets used once a week or so
and although the discs and pads were replaced a couple of years it was they have only done 2 or 3 thousand miles.
Rather than spend £100 on new discs all round I wondered if anyone has a lathe in the close vicinity to me that I could have a go at skimming the
discs on please? It probably isn't worth paying someone to skim them as it would cost nearly as much as a set of new ones - or am I being
stupid?
Mooky
| posted on 28/10/12 at 07:56 AM |
Unless they are badly pitted clean the edge corrosion off with a flap wheel in an electric drill or cup wire brush in an angry grinder then the
surface of ith 80 grade production paper, you can use an orbital sander or belt sander linisher.
MOT requirements don't require absolutely pristine disks.
| posted on 28/10/12 at 08:04 AM |
Some manufacturers can supply new pads with an abrasive surface that will clean the discs whilst bedding in (Peugeot at least) In the dim and distant
past BMC/British Leyland procedure for cleaning discs was to place some production paper between the pad and the disc with the car raised then chock
the opposite wheel and drive the car applying the brakes . Health and safety would have a field day but it worked. You may find just giving the car a
good run using the brake as much as possible will have the same effect?
Slimy38
| posted on 28/10/12 at 08:42 AM |
What he said, just take it for a ride in the country with plenty of hard braking, it'll clean them up. It'll also loosen the calipers up,
if you're only doing light miles chances are they're a bit sticky and may cause a bit of trouble at the MOT.
johnemms
| posted on 28/10/12 at 08:53 AM |
I used to jack up - wheel off - engine on - in a gear of choice..
While disc rotating - apply grinder - tidy edges & remove lip on disc.
Obviously - if the discs 'are' knackerd change em out!!
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
Ninehigh
| posted on 28/10/12 at 09:16 AM |
+1, if it's just surface rust it'll clean off naturally. Mine get rust on them all the time but then its gone when I get to work
mookaloid
| posted on 28/10/12 at 10:58 AM |
They are bad enough that they don't clean up on a good run out with some hard braking any more.
In the old days I would have had them skimmed but I'll try the flap wheel thing
| posted on 28/10/12 at 12:36 PM |
I can added have also used those paint stripper pads for the drill also work well but cost an arm and a leg from B&Q much cheaper from small
tools stores.
| posted on 28/10/12 at 09:26 PM |
Dont think it will be a huge problem at mot, ive changed pads onto seriously uneven discs (a pad had actually fallen out it was that worn), pads have
lasted ages and didnt get mentioned at the mot. Even if it fails you can fix it for the retest.
FASTdan
| posted on 1/11/12 at 01:37 PM |
This works superbly using a flap wheel as I have found out in the past I had a 924 that had stood for 5 years - rear discs looked completely shot,
but 5 mins a side with the above method had them looking like new and it sailed the MOT.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
