t11
| posted on 23/12/12 at 04:24 PM |
Cooling pipe's
Hi All.......does any one know where I can get some water pipe's made up, they have to run side by side with 90deg bends at either end,
I've tried Merlin motor sport but they can only do a radius of 112mm...any idear's.........
mark chandler
| posted on 23/12/12 at 05:07 PM |
I used 1" central heating copper pipe and soldered 90 degree elbows.
russbost
| posted on 23/12/12 at 05:22 PM |
I can make up anything you want in ali tube in either 25mm or 32mm, with beaded ends but I will need to check what minimum radius is I can do, I have
a suspicion it may be same as Merlin
renetom
| posted on 23/12/12 at 05:58 PM |
pipes
Hi
I agree 22 or 28mm copper pipe
With 90 degree yorkshire elbows.
Cheap as chips, job done.
Good luck
René
[Edited on 23/12/12 by renetom]
austin man
| posted on 23/12/12 at 07:13 PM |
you could always cut it at 45 degrees and weld or fit samco elbows
| posted on 23/12/12 at 07:15 PM |
Use straightish hoses with bends or black plastic 90 degree bends used for Koi ponds and irrigation.
T66
| posted on 23/12/12 at 07:35 PM |
Truflex stainless will bend, guy on Ebay will sell you lengths of your choice.
