corrado vr6
posted on 7/1/13 at 06:52 PM |
Air con on tin top
Hi there my sisters air on has run out of gas on her corsa which I knew about, but have always told her if you don't use it, it doesn't
matter, so save your money!
However she had a puncture repair done at ATS and the guy reckoned that because it runs off the belts that the bearings or something run dry and that
what they would do would stop future problems wether she uses the air con or not!
I told my sister it's probably another way of them making a little bit more money and to leave it
But just thought I'd check by asking on here just incase I'm wrong but I wouldn't have thought that re-gassing the system would make
any difference?
Thanks in advance
Greg
http://r1indy7.wordpress.com/
twybrow
posted on 7/1/13 at 06:59 PM |
I was told (not by ATS I might add!) that you should routinely run your air con problem for exactly that reason, and the fact that the pipe work tends
to crack/fail if is is not run periodically....
pewe
posted on 7/1/13 at 07:14 PM |
Correct - if you don't run the aircon occasionally it will lead to problems but whether that could lead to belt/bearing failure is
debatable.
However in my experience aircon cars clear steamed up windows faster so worth keeping it functioning.
Somewhere on here there was a discount code last year for half price aircon re-gass at ATS but don't know if it would still be valid.
No suprise they did try to sell an aircon sterilsation treatment at the same time and at full price.
I subsequently bought a three treatment kit by Wynns for much less than they were quoting!
HTH.
Cheers, Pewe10
posted on 7/1/13 at 07:31 PM |
The A/C compressor is lubricated by the oil added to the refrigerant but if the A/C is switched off the clutch on the A/C compressor isn't
engaged so the pump won't wear, so if the A/C stops working either get it investigated immediately or leave it permanently switched off.
Once a month you should run heating and AC the fully hot for 10 minutes then fully fully cold for 5 minutes then fully hot for 10 minutes
this will Pasteurise the heat exchanger get rid of bad smells. You should also check the scuttle drains are clear at the start of every winter ---
( for MG ZT/Rover 75 owners twice a year )
Just turning with the AC working or not on can cost a couple of MPG or more .....
I have recently switched from a Rover with the full BMW automated climate control to one with just basic manually controlled heating and A/C
and boy do miss the fully automatic climate control.
splitrivet
posted on 7/1/13 at 07:41 PM |
You should run AC occasionaly to keep shaft seal lubed to help protect against gas leak, but if you dont run it it wont cause any other problems.
Bob
Bare
posted on 7/1/13 at 09:53 PM |
Sounds like the ATS 'man' was a Numpty .. assuming that actually ..was.. what he said :-).
One can easily DIY Recharge their AC with inexpensive kits. A 5 min diy exercise... true.
Typically these use Propane as refrigerant.. and Work Fine.. being both benign to the AC system and the Ozone layer, unlike R12 and that Horrid
R134a... (which incidentally has a far lower flash point temp than R134A) .despite all babblings/dire predictions to the contrary.
Do your Due Diligence and go for it :-)
Dualist
posted on 7/1/13 at 10:07 PM |
Before you get her to re-gas it, find the cause of the leak first please.
quote: Originally posted by Bare One can easily DIY Recharge their AC with inexpensive kits. A 5 min diy exercise... true.
R134a...
Yes but as soon as you use a gas as a refrigerant it is an offense to vent it to atmosphere even R290 (propane).
[Edited on 7/1/13 by Dualist]
Rotary build coming soon...
quote: Originally posted by RichardK
I recently discovered that pigs can p i s s sideways when being transported
splitrivet
posted on 8/1/13 at 12:28 AM |
Depends on the state of charge if theres no positive pressure in the system it will need a vacuum pump out first.
Bob
jabs
posted on 8/1/13 at 07:55 AM |
It's not expensive to get it checked. My local garge charge £45 to degass / check for leaks and regass. Halfords often have an offer on at the
same price.
Macbeast
posted on 8/1/13 at 10:16 AM |
I had faulty aircon on my Nissan 200. The compressor was driven by its own belt so I just took that belt off and motored on happily.
ReMan
posted on 8/1/13 at 03:31 PM |
:-) my Saab is running a shorter belt that bypasses the a/c pump pulley (which has a worn out clutch bearing.
The car is on its last legs so no more money being spent on it (Poor thing)!
www.plusnine.co.uk
