T66
posted on 21/1/13 at 07:59 PM |
Classic Mini - Wiper spindle measurements?
Hi#
Im after anyone with a classic mini, who could measure between the wiper spindles for me ?
Plan is to fit a 2 speed mini/Lucas motor to the fiat.
Thank You
minitici
posted on 21/1/13 at 08:29 PM |
Too cold, dark & snowy to go out and look at my mini at the moment.
The mini spindle spacing should be easy to change - just cut the outer tubes, re-flare and fit the wheel boxes at the required distance apart.
T66
posted on 21/1/13 at 09:44 PM |
Am I correct - the wiper motor like this one .....this will shorten ?
Mini Classic Wiper Motor 2 Speed
myke pocock
posted on 21/1/13 at 09:46 PM |
Dont worry too much as they can be shortened. Just make sure you position the spindles correctly for the sweep of the wipers. I had mine slightly out
and the drivers side one just goes over the screen frame.
T66
posted on 21/1/13 at 10:55 PM |
ideal,,
as long as they can be shortened i will just but one - cheers guys
femster87
posted on 22/1/13 at 08:13 AM |
Yeap, I shortened and flared one for the kit car
lsdweb
posted on 22/1/13 at 01:46 PM |
SVC's Wiper guide is very helpful!
http://www.s-v-c.co.uk/wiper-systems/
Wyn
T66
posted on 22/1/13 at 05:04 PM |
Wyn
Nice one. Thanks for that.
Minicooper
posted on 22/1/13 at 06:03 PM |
At the risk of being shot down Ivan, what is wrong with using the fiat wiper system?
steve8274
posted on 22/1/13 at 06:51 PM |
Hi
Without wishing to hijack post, I was wondering if I could ask a few questions regarding fitment.
How do the wheel boxes attach to scuttle and what distance apart do they need to be?
I purchased a second hand motor with bundy tube,wheel boxes and wiper arms. However, there doesn't appear to be a way to attach wheels to
scuttle. It's an aluminium scuttle if it makes any difference.
All help appreciated
femster87
posted on 22/1/13 at 07:11 PM |
quote: Originally posted by steve8274
Hi
You want this.
http://minispares.com/product/Classic/Grilles_Brightwork/Wipers/Kits/37H6042C.aspx?160505&ReturnUrl=/product/Classic/Grilles_Brightwork/Wipers/Kit
s/37H7201MS.aspx|Back%20to
If you look the wheel boxes are threaded on the base
[Edited on 22/1/13 by femster87]
