Author: Subject: Coras B help please
jacko
posted on 3/3/13 at 12:38 PM Reply With Quote
Coras B help please
Hi All
The Boss [ Wife ] has a Corsa B and one of the rear springs had broke but while i was replacing [both ] springs i have noticed the chassis is getting a little rough above one of the spring
My question is can I buy a repair panel to weld above the spring ?
Thanks for any info
Jacko
designer
posted on 3/3/13 at 01:14 PM Reply With Quote
Ring a dealer!
posted on 3/3/13 at 02:07 PM Reply With Quote
After market Rust repair panels are a thing of the past these days except for Morris Minors, MGBs and the like.
If it so bad it needs welding is a Corsa B worth the investment in money and time ?
blakep82
posted on 3/3/13 at 02:16 PM Reply With Quote
Erm...
www.crashrepairparts.com/parts/markid/832/vauxhall_corsa_hatchback_1996_1998_facelift/body-repair-parts-and-panels?_ts=1
________________________
posted on 3/3/13 at 02:28 PM Reply With Quote
Erm...
Which only underlines my point, rust repair panels are a thing of the past in the old days you could get patch panels for just about any known rust point on any car.
Mark Allanson
posted on 3/3/13 at 02:38 PM Reply With Quote
Try a bodyshop affilliated with a Vauxhall dealer, very often we buy a complete chassis leg and only use the last 9 inches, and chuck the remains in the glory bin in case it is needed at a later date.
BT is right about the corrosion repair panels, one of the few available these days is the Ford Ka fuel flap surround
ashg
posted on 3/3/13 at 03:24 PM Reply With Quote
go to the scrappy and cut the bit you want out of another one!
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
jacko
posted on 3/3/13 at 06:10 PM Reply With Quote
Yes i think so
The panel is not that bad to need to change the car and i am sure it will be ok for another year or two but if i could have bought a repair panel i would have spent the time and money doing it
+ its cheaper then buying another car
Jacko
