mookaloid
| posted on 7/3/13 at 11:54 PM |
Golf engine dilemma
Daughters car (again) 1.6 golf 2000 my AKL engine.
Uses huge amounts of oil, has a suspect spark plug thread, and the clutch is close to the end of it's useful life.
These engines seem to have a rep for burning oil past the rings - I have driven it and there is no noticeable smoke but it is using I guess around a
litre in 500 miles..
So do I rebuild the motor with new rings (assuming the pistons are ok) fix the plug thread and replace the clutch
Bung in an ebay motor and hope for the best
sell it
Looking for the most cost effective option
matt_gsxr
| posted on 8/3/13 at 12:55 AM |
Try to think like your daughter.
Its not about what makes sense. It is about what will make her happiest.
No, I don't know the answer, but I bet you can work it out.
Matt
| posted on 8/3/13 at 08:04 AM |
Depends on the condition of the rest of the car and what facilities you have but my instinct would be do the rounds of the auctions to find a
replacement.
Fitting new rings to worn engine even with preping the bores with a glaze buster or hone is a hit or miss job, it might work it might not.
r1_pete
| posted on 8/3/13 at 08:07 AM |
Whats the milage? if its high I'd go for a low milage replacement, or sell it, re ringing would probably be a waste of time if the bores are
worn, and gone oval / tapered, and re boring / new pistons is going to exceed replacement engine cost.
Try and get an engine from an accident damaged car, not one broken because it was beyond MOT repair.
chris-g
| posted on 8/3/13 at 08:54 AM |
It would be a shame to do all that work to the car and then sell it and let someone else have the benefit of your hard work. If it was me and I wanted
to replace the car I would sell it on as going concern and accept that I am going to get a below market price due to its condition.
| posted on 8/3/13 at 11:13 AM |
It is a buyer's market especially in older cars, the market is so low even a long established car auction house went bust last week
because next to nothing was actually selling.
| posted on 8/3/13 at 03:19 PM |
Move it on and get something else would be my instinct at that age.
1.6 Golfs of that era also suffer issues with the crown wheel breaking it's rivets and mashing the gearbox. There's a fix by removing the
rivets and fitting bolts, so you'd want to do that as well if the start taking it apart for the clutch.
