morcus
| posted on 10/3/13 at 03:16 PM |
Help with radio.
The Radio in my car needs the code which I haven't got. I googled how to get the code and found a website that can tell me it if I have the
serial number on the side of the radio. I got some of the fork things to pull out the radio but I think the things you press with them have broken
off, I've never done this before but they've moved backwards and the radio itself doesn't seem to want to move.
What I want is either another way to get the code, or to get the radio out. I'd quite like a DAB so if I've got to destroy the radio to
get it out, so be it, the screen is broken anyway. Any sugeestions?
SALAD
| posted on 10/3/13 at 03:51 PM |
Whilst trying to avoid scratching your dash, just stick them in there and give it a wiggle about!
wilkingj
| posted on 10/3/13 at 04:01 PM |
What sort of car?
Which model Radio?
A picture might help.
My Mondeo was a pig, all done by feel, and the special tool was a must have.
Best Regards
Geoff
http://www.v8viento.co.uk
swanny
| posted on 10/3/13 at 04:08 PM |
Buy your new one from halfords and get them to struggle with it :-)
morcus
| posted on 10/3/13 at 04:36 PM |
A bit of an update. I had a look on youtube and realised there where some hex bolts in the way so I went out and took them out of the way and tried
again, the keys now go in a decent way and I can hear all kinds of clicks but can't seem to shift it, but It might just be a case of shaking it
about now as it feels like it's moving forward slightly.
It's a Delco CDR500 in a N reg Vectra 2.5 CDX just incase anyone has any specific tips, but from the sound of the replies so far, its just a
bugger to do. If I don't get it sorted by friday I'll be going to halfords and buying a new one. I was going to wait till next month but I
can afford to get one now.
on a related note, the arial doesn't seem to fit the screw whole, I'm going to test with some nuts and bolts but I think the whole is
about 5mm and the arial almost six (Couldn't find my measuring tools, I've got a Micrometer and a Vernier Caliper that I've never
actually used), the arial has a cut across the diameter on the bottom of the screw, if I squeeze it with pliers to close this gap is it likely to fit
in the hole? Otherwise I was going to find a bolt that will fit the hole and anut that fits the arial and glue them together.
morcus
| posted on 10/3/13 at 05:01 PM |
Thanks for the tips, I found my uncle and asked him to help and he basically did what you guys said, rammed them in and shook it.
Thanks for the tips
