Author: Subject: Gearbox Flushing
myke pocock
posted on 10/3/13 at 07:40 PM Reply With Quote
Gearbox Flushing
I use Millers TRX Fully Synthetic oil in my Skoda Estelle trials car transaxle. (It dont arf stick to the components and casing!!!) The diffs have a tendency to wear out in time, knocking bits of the sun and planet wheels. I am fitting another diff but want to flush the existing oil residue out and as it is in pieces on the bench I cannot run it in the car with any kind of flushing stuff in it. What can I use to flush out synthetic oils?
posted on 11/3/13 at 12:00 AM Reply With Quote
Any hydro-carbon solvent will do (Kerosene, Paint Thinners) but you want to be careful not to wash oil out the gear clusters.
It might be an idea to fix a magnet the bottom of the gearbox to catch swarf,
Any time I have an engine or gearbox in pieces I been modifying the drain plugs to take a very strong magnet and also doing the same with power steering reservoir dip sticks --- it is amazing how iron and steel is getting pumped around in power steering fluid.
