mookaloid
| posted on 17/3/13 at 08:34 PM |
Lambda sensor - which one?
So I have bought another Golf for the Daughter
Unfortunately I have an engine warning light with a P0153 code on the reader.
This apparently is a heater circuit on the Oxygen sensor - please can anyone confirm whether this is the front (pre cat) or rear (post cat) as I would
much prefer to get the right replacement first time
Many thanks
Mark
AndyW
| posted on 17/3/13 at 08:38 PM |
What year golf? What engine size?
Although that code suggests its upstream from the cat I.e bank 2
[Edited on 17/3/13 by AndyW]
mookaloid
| posted on 17/3/13 at 08:39 PM |
Ah ok its a 2003 1.6 16v
AndyW
| posted on 17/3/13 at 08:44 PM |
The info I have only shows 1 sensor but I will try and dig out a bit more info
mookaloid
| posted on 17/3/13 at 08:48 PM |
I did have a look under the car and it does have one at the front on the manifold and one after the cat underneath.
All assistance appreciated
AndyW
| posted on 17/3/13 at 08:49 PM |
If it has 2 I think it's the first sensor as a bit more digging shows a different code for B1S2 which would be a post cat. Hope that helps but I
would do a bit more digging yourself as what I think isn't gospel.
mookaloid
| posted on 17/3/13 at 09:19 PM |
OOPS just noticed the Code is P0135 not P0153
Sorry folks
| posted on 17/3/13 at 09:30 PM |
Bank 1 sensor 1 ie the sensor in the exhaust manifold.
Check the wiring and connector to be 100% sure the heater circuit is getting 12+Volts and a proper earth before changing anything.
If you need sensor the Gendan web site is a good place to buy.
You will need the engine code to get the right sensor.
[Edited on 17/3/13 by britishtrident]
mookaloid
| posted on 17/3/13 at 09:43 PM |
Thank you that helps
