I predict a Riot
| posted on 18/3/13 at 09:05 PM |
Re-threading advice please.
I recently managed to partially strip a thread in an aluminium casting in a really awkward to get at place.
I won't be able to get at it to fit a helicoil without removing the whole engine and gearbox - and I really don't want to do that.
The bolt is one of many that holds the gearbox/bell housing together and also clamps a small fabricated aluminium bracket that holds the speed sensor,
therefore the thread would not be highly stressed but I need to be able to slacken it off and re-tighten to adjust the sensor position.
So my question is - does a product exist such as a mastic or epoxy that I can inject, or cover the M10 bolt with, to create a new thread.
"Honesty is a very expensive gift. Do not expect it from cheap people ". Warren Buffet on Expectation
daviep
| posted on 18/3/13 at 09:19 PM |
The short answer is no....sorry
Only suggestion I can come up with if there any thread left would be to fit a stud and put it in with some loctite 638 retainer.
Davie
dave r
| posted on 18/3/13 at 09:36 PM |
enough metal left to retap a bit bigger ?
may be able to do that without removing ?
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
| posted on 18/3/13 at 09:40 PM |
It can probably live without it as structural bell-housing bolt until the engine is out so you could use Araldite or Loctite high strength grade
bearing fit to glue it in.
As an alternative I had a not dissimilar problem with the retaining bolt for the speedo sensor on a Pug gearbox I used one of these
10x Plastic Honda Grille, Wheel Arch Lining, Splashguard &' Bumper Trim Clips | eBay
The intention was to fix it at a late date but surprisingly it worked for 4 + years until the car was crushed.
I predict a Riot
| posted on 18/3/13 at 10:12 PM |
All good advice.
Thanks for your comments.
bi22le
| posted on 18/3/13 at 10:34 PM |
i would use some no nonsense metal to metal bond that comes in a music gun. the stuff is seems to work but does not set fully solid, very slightly
rubberish.
Please read my ring story:
inkafone
| posted on 19/3/13 at 12:00 AM |
Use a plasterboard fixing, the one with wings. A rawl plug will probably work as well.
[Edited on 19/3/13 by inkafone]
| posted on 19/3/13 at 01:24 AM |
But and bolt it?
ashg
| posted on 19/3/13 at 08:26 AM |
what you want is JBweld
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
owelly
| posted on 19/3/13 at 09:10 AM |
I'd use a stud or 10mm threaded rod. Degrease the styd and hole then bond in with Chemical Metal, Belzona, JB Weld etc. Alternatively, could you
find a Whitworth stud to fit? That would annoy any future folks working on the car...
http://www.ppcmag.co.uk
ReMan
| posted on 19/3/13 at 09:50 AM |
Could you not use a longer bolt just a thread or 3 longer?
www.plusnine.co.uk
