Nickp
| posted on 19/7/13 at 09:51 PM |
Aisan carb swap options?
I've a 30yr old Mitsubishi L300 on the drive (don't ask why!!). It seems to run a bit lumpy and rich with its old and over complicated
(vacuum secondary etc) Aisan carb. I'm a bit loathed to pull it apart to check float, jets etc as rebuild kits for these are like rocking horse
poo, and it is working in a fashion. A quick google showed up some guy swapping one for a Weber 32/36 on his old Toyota. Sounded like a win/win to me
but when I measured (roughly, in-situ) the bolt pattern on this particular one is smaller than a 32/36. The Weber is 47 x 93mm whereas the Aisan is
more like 40 x 80mm. An adapter could probably be made but just wondered if anyone could suggest a slightly smaller carb that may be closer to a
straight bolt on?
Thanks in advance,
Nick
r1_pete
| posted on 20/7/13 at 08:42 AM |
There were some webers fitted to the ford sierra twin cams and XR2 / 3s which had a smaller bolt pattern than a standard 28/36 etc weber.
You should be able to find one for next to nothing, maybe someone on here has one you could at least get measured up.
Nickp
| posted on 20/7/13 at 08:52 AM |
That's interesting, can anyone confirm this / measure one?
r1_pete
| posted on 20/7/13 at 09:30 PM |
This is one, ask this seller to measure it for you
ebay weber
[Edited on 20/7/13 by r1_pete]
Nickp
| posted on 21/7/13 at 09:03 PM |
ebay weber
Nice one ta
Spotted this while googling http://www.ebay.co.uk/itm/270458076394?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_260wt_1255
Looks like I'll be buying / making one of thes if I do end up Weber'ing it
