Hector.Brocklebank
| posted on 29/7/13 at 04:50 PM |
Custom Pulley
Hi Guys & Gals
Not car related I know but i just had to share the picture.
I am supercharging a BMW R1150R (just to scare the poop outta super bike riders)
I had them machine a custom trigger pattern (24-1 hayabusa)so I can run my M.B.E ECU
The pulley is run off the crank driving the alternator & the rotrex charger
Some people can never handle the truth and always try to shoot the messenger instead of taking an honest look in the mirror (its always easier to
blame another than to face reality), but secretly they wish they could grow a pair and be the messenger !!!
imp paul
| posted on 29/7/13 at 05:03 PM |
thats very nice mate mbe also good stuff it should be very rapid lol awesome pal
Hector.Brocklebank
| posted on 29/7/13 at 06:09 PM |
hmpphhh
I blame you for all this forced induction malarky, leading me astray and costing me money
imp paul
| posted on 29/7/13 at 06:16 PM |
lol ok mate i will take the blame but you know you love it haha power power and yes more power its the way we roll
omega0684
| posted on 29/7/13 at 08:44 PM |
Just out of curiosity (because i know nought about bike engines), how will the trigger wheel sensor pick up the signal? im presuming that you will
have to mount the sensor in front of the pulley facing the teeth. the teeth look very thin (from an end on view perspective) are they thick enough to
give a strong enough signal?
Hector.Brocklebank
| posted on 29/7/13 at 10:13 PM |
A picture speaks a thousand words as they say
The sensor(s) straddle the inside & outside of the teeth, the sensors are digital hall effect, so the teeth pass through the sensors
breaking/making the signal, its already been tested with teeth a lot smaller than those on my pulley, the reason for going for 24-1 (same as a
Hayabusa) is to get a higher signal resolution for the ECU, the sensor plate is mounted to the engine casing facing out straddling the crank and the
pulley bolts to the crank with the trigger teeth facing in, all very simple.
And technically even though I can do it in the ECU software, because of the slots in the plate where it mounts to the engine casing I could still
mechanically advance or retard the ignition if required.
Initially im only going to use one sensor, the top one but we may have custom code written for the ecu to make the lower sensor act like a cam sensor
to allow the system to run fully sequential.
This is my build thread on the whole bike is over at the R1150 forum
My build
TTS Tuning are supplying the Charger kit, and Richard & Darren have been great, the bike will eventually be getting mapped at Daytuner when I get
it all put together.
[Edited on 29/7/2013 by Hector.Brocklebank]
