ReMan
posted on 9/8/13 at 11:03 PM |
Toyota Yaris Clutch Change
My challenge if I choose to accept it....
Will I do it, over the weekend, on my own on the drive?
Any tips?
www.plusnine.co.uk
Mark Allanson
posted on 10/8/13 at 02:31 PM |
Press my [www]
ReMan
posted on 10/8/13 at 03:49 PM |
Thanks Mark.
Not sure what I'm supposed to see. Is there a mobile Toyata mechanic on his way to do it for me?
I've made a start on it even though I cant get a clutch kit till monday, and aI 'b beginning to wish I hadn't. I cant work out how
to get the driveshafts out at the moment so drinking tea!
Edited to add: I've managed to pop the driveshafts loose at the gearbox end now, just working out if I can get them out without take the wheels
and hubs off, hope so els i'm going to be a bit stuffed
[Edited on 10/8/13 by ReMan]
www.plusnine.co.uk
ReMan
posted on 17/8/13 at 07:22 PM |
Manuals got, clutch bought, engine crane snuck in under the cover of darkness, saturday used up and me very knackered but the new clutch is in and the
gearbox is back in and the engine is back on it's mounts. Hoping that a fine Sunday morning will get the all the othetr bits and bobbs back in
to finish it......
www.plusnine.co.uk
Mark Allanson
posted on 17/8/13 at 09:16 PM |
I love it when a plan comes together!
ReMan
posted on 17/8/13 at 09:33 PM |
![](/galpreviews/1173874_10151786716675490_1299121667_n.jpg) ![yaris clutch](/gallery/1173874_10151786716675490_1299121667_n.jpg) yaris clutch
Not very exiting, but you get the picture
www.plusnine.co.uk
Mark Allanson
posted on 17/8/13 at 09:41 PM |
Oh, the joys!
PeteForsyth
posted on 6/1/18 at 09:15 PM |
Just came across this thread. How did you get the clearance to slide the gearbox off the engine?
posted on 7/1/18 at 08:17 AM |
You lower the engine just enough , even doing the job on your back it should be possible in less than a day . Probably one of the easiest modern
clutches to do if nothing is siezed.
ReMan
posted on 7/1/18 at 10:18 AM |
I don’t recall that hard just twisting the engine and pushing down on the gearbox and obviously the wheel hub on the passenger side is off already I
can’t recall whether I took the engine off its mountings or not but as mentioned I didn’t find it too hard. With a bit of persuasion
Bit of a fiddle to get it back on again lined up good luck with it
www.plusnine.co.uk
