onenastyviper
posted on 17/8/13 at 09:39 AM |
What are the limits of the B+E category?
Hi Guys,
need some advice, I passed my license about 7 years ago(ish)
What does the B+E category actually allow, there seems to be very little info on what it allows, even on the DSA website...
Any help?
"If I knew what I was doing then it wouldn't be called research would it?...duh!"
bi22le
| posted on 17/8/13 at 09:59 AM |
I did a whole load or research regarding this as I have a new restricted licence.
There is a good post on pistonheads so search for that. Below is a post I sent last night to Blake82 as he U2U me regarding the same thing.
If your a youngun' like me and passed after 97 i think then you cant just tow anything you like. Essentially you cant tow a trailer that has a
stated gross \ max laden weight higher than the max tow weight of the tow car. This sounds stupid but if you have one of the grandad licencies then
you can use any trailer plate weight. So a trailer stating 2ton max can be used empty on a car with 1300kg max weight. You cant do this. The other
point you must satisfy is that the total weight of trailer (gross weight) plus max tow car weight can not exceed 3.5T (may infact be 3.75T). Thats
easy as long as you dont have a big tow car. I have a focus estate.
So, get a trailer that has a plated max axle weight more than the weight of your kit car but less than the max tow weight of tow vehicle. Make sure it
has a plate. If it does not then the plod go by tyre rating. for me (single wheel axle) its 1500kg so I would be in trouble with out the actual plate
stating only 850kg.
Order of plated gross max weight, highest first:
1) Car max tow weight
2) Trailer max tow weight
3) Car on trailer
For me, I have a focus estate with a max tow of 1300kg. My trialer had a max AXLE weight of 850kg. My car weights 540kg with out me. So Weight of the
striker and chasiss for the trailer will never be more than 850kg. 850kg is less than 1300kg. 850kg + wieight of filled focus estate will not be more
than 3.5t. This makes me legal on my basic licence.
The main pit fall is using a mainstream trailer with a big max gross weight, more than the max tow weight of the tow car. As you dont have the extra
tow bit on your liecence you cant be responsible for deciding how much the payload weighs on the trailer so even if you tow an empty trailer, becasue
it has a plate weight of 2ton its illegal.
I hope that makes it clearer. . .
[Edited on 17/8/13 by bi22le]
Please read my ring story:
theconrodkid
| posted on 17/8/13 at 10:10 AM |
thank god i,m old
[Edited on 17/8/13 by theconrodkid]
who cares who wins
pass the pork pies
coyoteboy
| posted on 17/8/13 at 10:24 AM |
It's dammed annoying. I missed out by months. and what is more, the government were forced into it by EU regs and they have no evidence that it
has helped road safety. The fact that the test covers things that /any/ trailer user should know, not just heavy one, shows how stupid it is. I plan
to take the test as I towed a heavy boat on a long heavy trailer for years without realising and could do with being legal to do it again.
Fwiw all the info is clearly available in a number of leaflets on the various government web sites these days.
matt_claydon
| posted on 17/8/13 at 10:38 AM |
B+E is full towing entitlement; the info above refers to what you can do with only B.
AFAIK, with B+E you can tow whatever you like up to 3500kg (plated max) as long as you stay within the car manufacturer's limits (see VIN plate
for max train weight and handbook for max trailer weight).
| posted on 17/8/13 at 11:33 AM |
DVLA says you can, quote:
You can already tow trailers of any weight with a car.
https://www.gov.uk/towing-rules/y/car-or-light-vehicle/no/before-jan-1997
Thats presuming you passed your test before Jan 97 and have B+E on your licence..
That quote is a bit misleading as it all comes down to the plate on the towing vehicle.
I passed a Range Rover the other day with a MASSSOOOF twin wheel trailer with a BIG farm tractor on it.. that got me thinking..
SteveWalker
| posted on 17/8/13 at 02:32 PM |
Landrovers used to be approved to tow 3.5 t and if fitted with interlinked braking system, 4.5 t !
phelpsa
| posted on 17/8/13 at 03:30 PM |
The Disco 2 I drive is 3.5 tonnes towing weight (6.75 GTW :O). It might be legal, but actually getting it to move with that weight would be tricky!
[Edited on 17-8-13 by phelpsa]
Volvorsport
| posted on 17/8/13 at 03:50 PM |
and if you have an old that car doesnt have a GTW on its VIN plate , then you can tow what you like ..... legally
ie an old volvo 240....
www.dbsmotorsport.co.uk
getting dirty under a bus
onenastyviper
| posted on 17/8/13 at 05:35 PM |
That's the impression I got but I cannot for the life of me find out any form of explicit statement from the Gov website.
Ninehigh
| posted on 18/8/13 at 01:01 PM |
Category E is a trailer above 750kg
