Robster
posted on 31/8/13 at 10:56 AM |
Ford Type E Gearbox
I am after a Ford Type E gearbox, the 4 speed version of the type 9, sometimes also known as the "rocket" box (although I believe the
rocket box was a special close ratio competition version).
I know this was fitted mainly to Cortina's, but also some Capri's, Escort RS2000 and early Sierra's. I've tried on eBay but
they don't seem to come up much, just wondered if anyone on here had one they were willing to part with!
Rob.
jonrotheray
posted on 31/8/13 at 01:10 PM |
Got one in Handcross...
Jon
teegray19
posted on 31/8/13 at 07:06 PM |
I've got one currently fitted to the crossflow.
It's coming out over the winter if you can wait?
phil clegg
posted on 1/9/13 at 03:01 PM |
gearbox
i have a ford 4 speed box for sale £45 it has these markings,70/g.7006db-r34 7a11a3 69ag 7a039gn .can anybody tell me which one it is,its been
removed from a kit car with a711 crossflow,thanks
phil clegg
gearbox
posted on 1/9/13 at 04:33 PM |
You can tell a lot from the first and second gear ratios. The most desirable standard production 4 speed boxes had 2000e ratios.
With 2000e ratios 1st gear requires almost exactly 3 turns of the input shaft to one of the output, 2nd gear requires 2 turns of the input to 1
of the output.
Link to pdf
Robster
posted on 1/9/13 at 07:05 PM |
The number of splines on the input shaft also helps identify - generally 20 splines means it is a type 2 or type 3, 23 splines is a type E or type
9.
Teegray19 - if it's definitely a Type E then yes i am interested. Ideally after one sooner if anyone has one, but if not pls can i have first
dibs when it comes out. ![](/images//smilies/smile.gif)
rash12
posted on 1/9/13 at 09:28 PM |
gearbox
you have u2u
RhinoRacing
posted on 2/9/13 at 11:35 AM |
I have a 4spd tranx (competition) rocket box that's off for a refresh with SPC at the moment.
Let me know if you are interested - 07929937684
H.
