Author: Subject: MG Manual Wanted
myke pocock
posted on 6/9/13 at 08:03 PM Reply With Quote
MG Manual Wanted
I have promised to help my mate strip and rebuild the engine of his MG TC as it has comprehensively run a big end bearing, fresh con rod and reground crank needed at the least. HOWEVER, he doesnt have a workshop manualand I dont want to tackle the job without one. There are manuals on ebay but only for maintenance, not strip and rebuild of the engine. Does anyone (long shot I know) know of a manual available to rent, lend or copy or even just the relevant engine part?
ste
posted on 6/9/13 at 08:37 PM Reply With Quote
This may be of use
http://www.mossmotoring.com/disassembling-british-engine/
posted on 6/9/13 at 09:00 PM Reply With Quote
The MG XPAG 1250cc is dead simple engine only thing to watch is the cam timing marks are not conventional the marks on sprockets have to align with pre-made marks on the chain. Like most engines of the period the pistons cannot be drawn upward through the cylinder bores but can only come out after the engine is out the car and the crankshaft removed. The camshaft bearings are also a bit of an odd design. The camshaft centre bearing is split white metal type held in by a single set screw from the outside of the block. In any event the camshaft can be left undisturbed during most major overhauls.
Anything else just ask I know these engines pretty well to the last nut and bolt.
The best manual to look for is "The Tuning and Maintenance of MGs" by Phillip H Smith. It is very comprehensive.
I may have an alternative T type manual kicking about I'ill have a look
[Edited on 6/9/13 by britishtrident]
posted on 6/9/13 at 09:29 PM Reply With Quote
Originally posted by ste
This may be of use
Don't follow too closely the engine featured is an Austin (later BMC/BL) A series engine the MG TC has an XPAG engine a pre-WW2 engine developed from the early 1930s Morris 10 engine.
One thing I forgot to mention is all the threads on the XPAG are BSF or BSW and the hex sizes are Imperial (NB not inch AF) .
myke pocock
posted on 7/9/13 at 07:07 AM Reply With Quote
britishtrident, that would be great if you have one. Cheers.
