myke pocock
| posted on 2/10/13 at 07:22 PM |
Honda HR-V
Anyone know if the 2wd HR-V is front or rear wheel drive? If it is fwd is it possible to take the front drive of a 4wd version to make it rwd only?
adithorp
| posted on 2/10/13 at 07:51 PM |
It's front wheel drive. The 4wd is front wheel drive but has a viscous coupling to the rear axle like other softroaders. can't see how it
could be made RWD.
http://jpsc.org.uk/forum/
myke pocock
| posted on 2/10/13 at 08:03 PM |
Thanks for that. End of an idea.
hearbear
| posted on 3/10/13 at 09:21 AM |
could be made RWD.
In that case then could you remove the prop to the rear like you can on the freelander and run it as a front wheel drive?
3.9Ltr SSC Stylus should be fun
