Author: Subject: Second Moment of area
liam.mccaffrey
posted on 4/11/13 at 08:39 PM Reply With Quote
Anyone know how to calculate second moment of area for a fabricated column such as this one below. Its made from 2 standard channels welded together
api column
api column
Build Blog
Build Photo Album
mcerd1
posted on 4/11/13 at 09:41 PM Reply With Quote
how accurate does it need to be ?
if you don't mind ignoring the radii then you can easily use parallel axis theorem on each of the rectangular bits...
[edit]
this video gives you the idea:
[Edited on 5/11/2013 by mcerd1]
flak monkey
posted on 4/11/13 at 10:13 PM Reply With Quote
Easy way? Sketch it in Solidworks or other 3d modelling software and have a look at the section properties and it will tell you
Smokey mow
posted on 4/11/13 at 11:02 PM Reply With Quote
As they are drawn in the pic you can calculate for each of the shapes and then add the results to obtain the second moment of area for the assembly.
mcerd1
posted on 5/11/13 at 08:28 AM Reply With Quote
do you have the sizes of the 2 channel sections ?
