corrado vr6
| posted on 28/2/14 at 08:42 PM |
Body mounts
Hi all, I need to make some body mounts like this on my Suzuki sj chassis but slightly taller
I only have access to flat sheet metal and a welder can anyone think of a strong way/ design to make them?
http://r1indy7.wordpress.com/
Smoking Frog
| posted on 28/2/14 at 08:57 PM |
Depending on the size needed I would be tempted to use some thick walled box section. Maybe a fillet (is that the right word?) either side for added
strength.
loggyboy
| posted on 28/2/14 at 09:24 PM |
Simple 4 sided box section. Do u need to access the underside of the top?
Mistral Motorsport
bi22le
| posted on 28/2/14 at 11:33 PM |
strength.
yup, right term. Fillet or web will suffice.
Please read my ring story:
Simon
| posted on 1/3/14 at 12:49 PM |
Agree with box, weld a plate on top and drill tap or weld captive nut to underside of plate before welding onto top hole - but I'd cut so you
have a bit of overhang down side of chassis rail.
Simon
