stevebubs
| posted on 1/4/14 at 12:20 AM |
Elm327 device
Right ... I have a cheap Elm327 bluetooth dongle. However it appears to be unable to communicate using the PWM protocol required by my Mondy to read
DTC codes. Does anyone have a recommendation of an Elm supplier that may work?
Linky to non-compliant device
| posted on 1/4/14 at 07:15 AM |
If you go to the Ian Hawkins Torque website you will find links to what you are looking for.
Be aware a genuine Torque chip is relatively expensive and these dongles are more expensive.
MikeR
| posted on 1/4/14 at 07:20 AM |
Search eBay for a fordsuper. This reads the extended ford codes.
40inches
| posted on 1/4/14 at 07:32 AM |
You may find something here. Gendan
bimbleuk
| posted on 1/4/14 at 09:51 AM |
PLX Kiwi devices are well supported and will work as fast as the OBD port can supply data. That can be another downside to the cheaper more generic
devices.
v8kid
| posted on 1/4/14 at 02:45 PM |
I bought a cheap V gate from ebay and it works fine with me on Torque on Ford and Honda. I only bought it cos it has an on/off switch as there was a
scare about cheapo ones flattening batteries.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
