jacko
posted on 5/4/14 at 01:35 PM |
Fiat 500 service ?
Hi all
Has anyone serviced a fiat 500 1.2 L car
Or dose anyone work for fiat dealers ?
If so what are they like to do, do i need any special tools to do the jobs ?
Jacko
NigeEss
| posted on 5/4/14 at 01:58 PM |
Simple, nothing special required.
jacko
| posted on 5/4/14 at 02:11 PM |
That's good as i have just bought one for the wife
Any tips you can give me will be great
Jacko
mookaloid
changing the front brake pads was the easiest I've ever come across on a car
NigeEss
| posted on 5/4/14 at 02:43 PM |
The top of the front suspension strut gets full of water. I've seen 08 cars that are so corroded the nut
had to be cut off to replace the spring. I usually liberally dose them with WD40 or similar and a big gob of
grease. Later cars have a rubber cap on them.
Also, bottom ball joints are prone to wear.
| posted on 5/4/14 at 03:42 PM |
Door handles are weak , I've changed a few wiper motors for some reason and IIRC a coil pack ,everything pretty easy to do
