Dusty
| posted on 6/4/14 at 04:36 PM |
Poor returning clutch pedal
I have a polo saloon 1.9 TDI with hydraulic clutch. As a drive progresses the clutch pedal returns slightly les each press until it's quite low
and a press doesn't quite release the clutch so I grind the gears. I hook my foot behind the pedal, lift it and all is normal for another 10-20
gear changes.
I thought it might be a sticky master cylinder but that would return to the same albeit low position each stroke. Almost as if it looses a little
fluid each time but I can't find a leak and the reservoir level doesn't seem to drop.
Anyone any ideas. I suspect I need a new master cylinder but I would like to avoid that cost as it's only a guess.
Nigel
jacko
| posted on 6/4/14 at 05:15 PM |
Pedal bearing seizing ?
pmc_3
| posted on 6/4/14 at 05:26 PM |
I had a similar problem on an mgf recently, new slave cylinder solved it
| posted on 6/4/14 at 06:36 PM |
gear changes.
Nigel
All the symptoms of a failing recuperating seal in the master cylinder.
| posted on 6/4/14 at 06:44 PM |
It was probably just stripping down to fit the new slave that cure it.
Probnlems with the clutchn release on the Rover Pg1 gearbox in the MGF it is usually caused by the shaft the clutch release fork pivots on in the
bellhousing partly seizing in its bearings.
The shaft runs directly in the aluminium alloy of the bell housing and suffers from corrosion.
Dingz
| posted on 6/4/14 at 07:11 PM |
Can you get a seal kit for it Nigel or is it a new cylinder only?
went on and on.
Dusty
| posted on 6/4/14 at 11:08 PM |
Master cylinder recuperating seal needs a bit of recuperation. Thanks for the help.
I will search for seal kits online. Problem is polo saloon is a bit of an oddity. Half polo and half cordoba and not a huge number on the roads.
[Edited on 6/4/14 by Dusty]
