Benzine
posted on 21/4/14 at 06:28 PM |
Stubborn studs
I have this little turbo, TD04. He is small, and very funny.
Two of the exhaust studs came out with no problems. The other two started to undo for about 3 turns. Then they became stiff, and then even turning
them back the way they became stiff. One I can turn about 45 degrees, the other about 120. Heat only seems to make them stiffer. Soaking in
penetrating oil isn't helping. Why have they done this? How would you go about releasing them?
olimarler
posted on 21/4/14 at 07:29 PM |
I have a stud puller wrench would work a treat! Chrome vanadium do one used them on my head bolts on my mr2 turbo
Oli
[Edited on 21/4/14 by olimarler]
olimarler
posted on 21/4/14 at 07:34 PM |
http://www.ebay.co.uk/itm/like/160786498077?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=t&adtype=pla
&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108
adithorp
posted on 21/4/14 at 07:50 PM |
Sounds like they've dragged the threads in the bottom of the hole. Often caused by the stud screwing right to the bottom of the tapped hole and
damaging the end thread. As the damaged bit on the stud gets to the good threads in the casting it binds up.
Not a lot of choice but to force them out and (if the threads are damaged) fit heli-coils in my experience.
http://jpsc.org.uk/forum/
olimarler
posted on 21/4/14 at 07:56 PM |
Never had damage to the holes using the stud puller. The stud was screwed though.
posted on 21/4/14 at 07:58 PM |
Electrolysis my friend....
matt_gsxr
posted on 21/4/14 at 08:31 PM |
I had a similar thing happen on my exact same turbo. One of the studs seemed fairly loose, but just jammed up like yours.
Ended up drilling it out.
In my case I used a bolt instead as it was accessible from both sides in my car. Seems to work fine like that for me.
Matt
Benzine
posted on 22/4/14 at 12:26 PM |
Electrolysis sounds like a good idea. How do those stud pullers work? I have no problems with gripping the stud, if I turn it any more the studs will
shear
The other thing I could try is putting it in a pan of v hot oil. I've used that with great success recently but only just remembered
[Edited on 22-4-2014 by Benzine]
dave_424
posted on 22/4/14 at 12:29 PM |
Some people have good luck with heating the area up hot and pushing a candle or other source of wax into the joint, seems to flow right down into the
threads and help.
DW100
posted on 22/4/14 at 02:31 PM |
Oli
Are you thinking that Chrome Vanadium is a make of tool?
olimarler
posted on 22/4/14 at 02:52 PM |
Oli
Lol oooops just copied down what was on the tool
olimarler
posted on 22/4/14 at 02:54 PM |
shear
Difficult to explain. But you Place the puller over the stud and then turn with wrench. It tightens itself around the stud and grips onto it.
Oli
adithorp
posted on 22/4/14 at 03:01 PM |
...How do those stud pullers work? I have no problems with gripping the stud, if I turn it any more the studs will shear
Oli
So it's not really going to help.
Matt21
posted on 22/4/14 at 03:05 PM |
Oli
someone had to ask
ive got to admit, it gave me a little chuckle
