Author: Subject: Plastic V8 engine needed for a go-kart
posted on 23/5/14 at 08:37 AM Reply With Quote
Some of you may recall I built a cart last year for a local downhill go-kart race...
http://www.locostbuilders.co.uk/viewthread.php?tid=183119
Well this year we're building a second kart with a Hot Rod theme and we need a model V8 engine to fit on the front. I've had a Google and looked on eBay, but can't seem to find anything suitable.
Anyone got any ideas...???
(given time I could probably make one, but as ever, time is short)
[Edited on 23/5/14 by nick205]
stevebubs
posted on 23/5/14 at 08:56 AM Reply With Quote
V8 Haynes plastic model?
posted on 23/5/14 at 09:11 AM Reply With Quote
That might well be an option!
Will measure up tonight and see how it works for scale on the kart.
Thanks Steve
Nickp
posted on 23/5/14 at 09:54 AM Reply With Quote
Just put a real one in, surely the momentum of an old iron block Chevy will win the race for you too
MikeR
posted on 23/5/14 at 11:06 AM Reply With Quote
Couldn't you "make" one?
Bit of MDF cut into rectangles, glued togother would make a 'head'. Glue / screw to a larger rectangle at an angle for the block. Make the block into a square. Drill some holes and fit some leads. Paint black / silver. For exhause I suspect plastic waste pipe would look great once painted silver.
A few hours should make something passable .... ish.
If you want to cheat fill the engine block with sand.
posted on 23/5/14 at 11:25 AM Reply With Quote
I could do, but I'm limited on time and will probably only just get the rest of the kart finished in time as it is.
bi22le
posted on 23/5/14 at 11:34 PM Reply With Quote
I would concentrate on making our safe and fast and not care about detail. As you say, you are going to be lucky to even finish it on time.
Put a bonnet on ir and forgery about the detail.
Please read my ring story:
Nickp
posted on 24/5/14 at 04:42 AM Reply With Quote
+1, just stick 8 pipes out of the bonnet
loggyboy
posted on 25/5/14 at 01:34 AM Reply With Quote
A few bits of wood cut up to make the v block, then two matching rockers from any small engine?
Mistral Motorsport
TheGiantTribble
posted on 25/5/14 at 08:31 AM Reply With Quote
Cut up a block or two of polystyrene, and add 8 pipes of pipe/small flower pots for trumpets
stand back and admire, just don't look too closely :-)
RaveyDaveyDave
posted on 12/6/14 at 03:39 PM Reply With Quote
Pic makes me smile.......
Why has your boy got a helmet on if the cart has no wheels?
Has he been around dads handywork before?????????????
posted on 12/6/14 at 09:18 PM Reply With Quote
will we get an update and pics of what was finally made .... before it gets crashed
