Author: Subject: Steering, how best to shorten this
corrado vr6
posted on 24/5/14 at 02:20 PM Reply With Quote
Afternoon all, can anyone suggest a good way to shorten this by 2 inches after a nice strong suggestion?
Would just welding it back together be strong enough??
This is from a Suzuki sj413
http://r1indy7.wordpress.com/
theconrodkid
posted on 24/5/14 at 02:31 PM Reply With Quote
it,s part of a colapsible column,the inner will slide into the outer
who cares who wins
pass the pork pies
designer
posted on 24/5/14 at 02:37 PM Reply With Quote
it,s part of a collapsible column,the inner will slide into the outer
Yes, have to agree. If not cut, shorten and sleeve lower down.
Staple balls
posted on 24/5/14 at 03:12 PM Reply With Quote
ISTR there's a clamp on jobber from CBS that replaces the rubber with an (admittedly, a bit crap) UJ , about as strong and safe as you can do it I reckon.
This I think, actually looks a bit less crap than the one I have.
jacko
posted on 24/5/14 at 03:20 PM Reply With Quote
The inner slides in and out so wont that be short enough or can you pull the inner out and cut so much off the inner end ?
[Edited on 24/5/14 by jacko]
corrado vr6
posted on 24/5/14 at 04:36 PM Reply With Quote
Well this is easier than I thought I'll check tomorrow, hopefully if it just slides that'll be a nice easy job
adithorp
posted on 24/5/14 at 04:44 PM Reply With Quote
It'll be fairly tight and some have some shear off plastic pegs to overcome (don't think Ford did). I'd give the lower section a clean with emery first and apply a bit of grease to prevent forcing the rust/crap in and it binding up.
http://jpsc.org.uk/forum/
