coyoteboy
| posted on 30/5/14 at 09:55 PM |
FDSH not worth it
Other half's celica was running a bit rough. Coming up due the 40K mile plug change (iridiums are OEM) - pop them out to change - copper, and
the wrong heat range. Burned down to a gap of about 2.1mm (should be 1.1). No wonder it was stumbling a bit and the economy was dropping!
| posted on 31/5/14 at 08:21 AM |
I'm not a fan of dealer servicing either, they charge too much and do the bare minimum. Do what you can yourself and use a decent independent
for the bits you can't.
