Author: Subject: Friday Fun, Guess the fault....
AndyW
posted on 4/7/14 at 01:29 PM Reply With Quote
Hi all,
Having got my car back from France after a disappointing break down at Le Mans, I thought a bit of Friday fun was in order to guess the fault. Here are the DTC's that the ECU logged. Its a 2.0 blacktop running standard ecu.
P0500
P0442
P1401
P1409
PO171
PO172
PO122
P1130
P1131
Fixed now, so lets have some guesses.
loggyboy
posted on 4/7/14 at 01:34 PM Reply With Quote
Bad earth.
Mistral Motorsport
Benzine
posted on 4/7/14 at 01:41 PM Reply With Quote
mark chandler
posted on 4/7/14 at 02:05 PM Reply With Quote
Out of fuel, blocked fuel filter, starts running weak and loads of codes pop up as the mixture is screwed up.
[Edited on 4/7/14 by mark chandler]
Ugg10
posted on 4/7/14 at 02:13 PM Reply With Quote
Dodgy tps or possibly lambda sensor.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
big_wasa
posted on 4/7/14 at 02:21 PM Reply With Quote
p0500 No speed sensor signal, no shock there as I doubt you have one.
p0442 Evap leak, again you don't have one.
p1401 Egr, guess what. Yep your not using one.
p1409 Egr, see above.
The above four would be on the ecu with in minuets of your first drive and do not give any limp home symptoms.
p0171 Bank 1 lean
p0172 Bank 1 Rich
p0122 Tps low
p1130 O2 sensor switching, low
p1131 O2 sensor lean.
One of two things in my opinion.
Most often and my money is an air leak.
Wiring fault / break. Either with voltage supply. Earth as above or sensor earth.
So if there are no air leaks check for 12v at all the sensors.
Then disconnect the ecu and check continuity of the broken sensor common wire and the black/yellow earths.
[Edited on 4/7/14 by big_wasa]
whitestu
posted on 4/7/14 at 02:24 PM Reply With Quote
PO171 is 'Wasted money on fancy ecu and throttle bodies - should have bought carbs instead that you could fix at the side of the road'
Sorry, couldn't resist!
Glad it is back and fixed
Stu
AndyW
p0171 Bank 1 lean
p0172 Bank 1 Rich
p0122 Tps low
No air leaks, earths checked out.
The faulty part did not throw up an error code, but forced the others for some reason, replaced faulty part, cleared codes and tested, all ok. So, what was it...lol
big_wasa
posted on 4/7/14 at 02:28 PM Reply With Quote
What faulty part ? as a short would cause a voltage drop and give the codes ?
Only half the story blah blah blah.
AndyW
posted on 4/7/14 at 02:36 PM Reply With Quote
Warren you have u2u
rdodger
posted on 4/7/14 at 02:41 PM Reply With Quote
Crank sensor?
kj
posted on 4/7/14 at 03:13 PM Reply With Quote
Shity grade fuel or fuel surge / air lock
Think about it, think about it again and then do it.
sebastiaan
posted on 4/7/14 at 03:24 PM Reply With Quote
Fuel pressure regulator?
AndyW
posted on 4/7/14 at 06:15 PM Reply With Quote
And the answer was.....
Coil pack
Bloomin kit cars
