Irony
| posted on 13/7/14 at 09:02 AM |
Cmax/Focus Brake issue
My Diesel Cmax has a brake issue. Bit scary as it's the missus's car and we have a toddler. You start the car from cold and the brake
pedel is stiff as you like. Almost as if the power brakes aren't working. Very little braking effort. Literally 2min later the brakes are
working perfect and keep on being perfect. When starting from hot no problems. Then leave it overnight, same problem.
Any ideas?
[Edited on 13/7/14 by Irony]
| posted on 13/7/14 at 09:32 AM |
Start by checking for a vacuum at the servo when cold
| posted on 13/7/14 at 10:06 AM |
As above sounds like a collapsed servo hose or faulty or leaking vacuum check valve, if not could be abs pump fault.
Irony
| posted on 13/7/14 at 11:25 AM |
I'll have to google how to do those things, no experience with these systems.
avagolen
| posted on 13/7/14 at 03:28 PM |
As it is a diesel, does it not have a vacuum pump somewhere?
No experience, but I have heard some are part of the Alternator.
Maybe the more experienced Ford guru's could comment.
luke2152
| posted on 13/7/14 at 10:20 PM |
Often driven off the cam too but no experience either with these engines
mcerd1
| posted on 15/7/14 at 12:41 PM |
found this recall - even if yours isn't covered by the recall it could be a similar issue..
http://www.dft.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=24E73DECF50DE9C6802575AF002C8B13&freeText=Blank&tx=
