mark b
| posted on 16/9/14 at 10:33 PM |
silver top fan belt
I'm about to put a silver top in my locost and one of the jobs to sort is the fan belt would anyone have some pics of their alternator bracket
and tensioner/idler pulley setup?
My email is mark.bishell@yahoo.com
Any help would be greatly appreciated
[Edited on 17/9/14 by mark b]
HowardB
| posted on 17/9/14 at 04:16 PM |
my alternator bracket
  new alternator bracket_1
hth
Howard
mark b
| posted on 17/9/14 at 06:29 PM |
That looks great thank you
Is yours a black top as you have a ribbed pulley on the water pump where mine has a smooth pulley?
Am I correct in thinking silver and black top water pumps go in opposite directions?
Is there a part number on your belt by any chance??
Thanks again
HowardB
| posted on 17/9/14 at 06:49 PM |
it's a silver top, I have a spare water pump, it has the same ribbed pulley.
I recall there being posts about the pumps running in different directions.
I may have some pictures somewhere,...
Howard
mark b
| posted on 17/9/14 at 07:19 PM |
I may have a black top pulley then and if that's the case it will make life a lot easier
I don't suppose you could look to see if your belt has a part number on it if you don't mind it would be greatly appreciated
big_wasa
| posted on 17/9/14 at 08:29 PM |
The blacktop pulley wont fit the silvertop so you wont have one of them.
If it has the smooth pulley you either need the escort / fiesta water pump and pulley or an idler arrangement to run the pump the other way.
When done just measure it (in mm) with some string and buy the nearest you can find with the pulley pattern you need.
So in Halfords you would be looking for xxx6pk
Home made silvertop
https://www.dropbox.com/s/sm1orait2t55d1m/alternator%201.JPG?dl=0
home made blacktop / st170 setup
[Edited on 17/9/14 by big_wasa]
mark b
| posted on 17/9/14 at 09:43 PM |
It looks like I'm on the hunt fo a new water pump then
Thanks for your help
mark b
| posted on 2/10/14 at 05:54 PM |
Big thank you to Howard and big wasa as I got a pulley and escort water pump today
