Nickp
| posted on 13/2/15 at 08:25 AM |
When 1 V8 and 4 wheels just isn't enough....
The 1981 Wolfrace Sonic
JacksAvon
| posted on 13/2/15 at 10:39 AM |
It would be worth it to see the look on the traffic cops face
wylliezx9r
| posted on 13/2/15 at 10:41 AM |
I don't know weather to laugh or cry.
From the photos it has a plate on it. Meaning it may of been on the road at some point, imagine trying to park that in Tesco's.
George Best
Nickp
| posted on 13/2/15 at 11:11 AM |
It says it has a V5!!
I want to see the back axle. I presume it has 2 diffs, linked together somehow? Or 1 engine driving each back wheel?
r1_pete
| posted on 13/2/15 at 11:13 AM |
It most definitely was on the road in the early 80s, I remember seeing it at several Custom shows on the WolfRace stand, with road tax.
IIRC the engines are linked, driving a single jag IRS.
[Edited on 13/2/15 by r1_pete]
Slimy38
| posted on 13/2/15 at 11:28 AM |
It's just so utterly bonkers.... I love it!
Oddified
| posted on 13/2/15 at 11:55 AM |
Mad, but why not!. Watched the youtube vid link on the ebay add, looks like it has 2 jag diffs under the back, assume the inboard drive shafts are
just joined together....interesting.
Ian
James
| posted on 13/2/15 at 12:37 PM |
I need that in my life!!!
Love it! Sent the link to my girlfriend, she's asking difficult questions about how I'd afford it and where would it go...
I've told her I'm about to re-mortgage the house!
- Muhammad Ali
Mr Whippy
very old car that, I mind it in the mags
shame to see it has been neglected
mark chandler
| posted on 13/2/15 at 01:58 PM |
Two diffs at the back, sounds horrible but actually a good idea as the engine revs/gears may be mismatched which is then resolved by the diffs, the
planet gears could be racing, really need a pair of LSD's not open.
Slimy38
| posted on 13/2/15 at 02:01 PM |
Ian
I'm just trying to figure out how that would work, would the joined shafts just spin merrily away while the wheels stayed put?
Edit: Mmm, Marks answer may be the key, it would have to be an LSD. Although it would permanently be in 'limited slip' mode?
[Edited on 13/2/15 by Slimy38]
Sam_68
| posted on 13/2/15 at 02:27 PM |
I remember this car from when it was new.
Possibly just marketing hype (the was the early 1980's remember, when we thought a Sinclair ZX81 was high-tech) , but I distinctly remember that
they claimed the engines were synchronised by a custom-made management computer. They made a big deal about all the digital electronics on the dash,
too.
Gotta be a simpler way of doing it, like using the distributor from one engine to fire the spark plugs on the other, so that they've got
to run at the same revs cos of the ignition timing?
motorcycle_mayhem
| posted on 13/2/15 at 05:35 PM |
This is Ebay chaps...
Just hoping that "YNK 135X" isn't just another Dutton (!)
I don't think an HPI will matter, unless it's on a logbook loan....
| posted on 13/2/15 at 06:38 PM |
Looks like a Joye loader we used to use down the pit!
MikeR
| posted on 13/2/15 at 10:16 PM |
I have the space ......... Must resist
Simon
| posted on 14/2/15 at 05:16 PM |
Was wondering just recently whatever happened to that
Simon
Nickp
| posted on 14/2/15 at 05:46 PM |
Ahhh g'wan!!
scimjim
| posted on 16/2/15 at 12:09 AM |
scimjim
| posted on 16/2/15 at 12:54 AM |
Apparently, one welded and one LSD.
Grimsdale
| posted on 17/2/15 at 01:12 PM |
wouldn't that mean one engine's power only goes to 1 wheel and the other engine's power is shared between both? (albeit averaged out
a bit by the lsd)
Would it be better to have 2 diffs, both welded and not connected, allowing 1 engine to power 1 wheel alone?
[Edited on 17/2/15 by Grimsdale]
scimjim
| posted on 17/2/15 at 01:44 PM |
only if you could accurately match engine output. In the early 80s we had the same problem on the Lynx helicopter (the system was eventually disabled
and the co-pilot matches the torques manually) - Wolfrace had no hope on their budget
Simon
| posted on 19/2/15 at 08:33 PM |
Ends in 7 mins
Simon
Nickp
| posted on 19/2/15 at 09:12 PM |
WOW £18K!!
coyoteboy
| posted on 20/2/15 at 01:14 PM |
There's a lot of misinfo about dual engines - you don't really need to account for mismatched output speeds (unless they're wildly
different engines rigid-linked to the same shaft of course!) and you don't have to worry to such a great extent - the same way as adding 4 more
pistons to a crankshaft - you just lock the outputs together and force one engine/box to work at the same rate as the other - total torque is the sum
of the two whether they're slightly imbalanced or not. You'll get a few odd dynamics going on, sure, but it's little different to
having one piston in a 4 banger running a little low on compression - they'll all run at the same speed but it'll contribute slightly less
to the output.
[Edited on 20/2/15 by coyoteboy]
