Considering it was an 'unassisted' launch as the flatshift and traction control is still not working and it was on cold tyres I think it
is pretty respectable.
I actual didn't achieve anything as I got no time for that run as I caught the car in front. I then got the Clerk of the Course excluding me
for the noise infraction once I came back in.
Photo Archive
Building: Sold turboblade, back to tin tops
posted on 10/5/15 at 05:17 AM
Having been excluded from running my little car around Goodwood before so ended up driving the tow car on a track day what has changed? You have
plenty of previous videos from Goodwood, not something stupid like due to having two cars on at once tripping things?
Note, when I was excluded they had a Ginetta and little 16v nova that passed exhaust noise, the scream from the induction was really loud!
I had the same issues at Anglesey in the radical last year when my best time was 48 secs quicker tan the car in front of me. I was asking the marshals
for a huge gap otherwise I was On him after half a lap. I ended up sitting on the start line for about 30 secs with the green light on, refusing to
set off!
The rear exit was certainly better at getting by at Goodwood as it isn't pointing at the noise meters which are on the outside of Madgewick and
St Marys. I always pass the static (99dB) but the car failed the drive by at 108dB (limit if 101dB).
I'm actually starting to wonder if the issue is gearchanges without the clutch which causes the exhaust to flame as you change up. It might be
the flatshifter will be better as it retards the ignition rather than me just slightly lifting the throttle. I drove as fast round Madgewick in
practise and didn't get picked up. The problem is you don't get to try different things while they tell what works and what didn't,
you just get sent home.
Photo Archive
Building: MK Indy, Jaguar AJ30. Sold. Now a GTM Spyder
posted on 11/5/15 at 07:49 AM
quote:Originally posted by jeffw
The problem is you don't get to try different things while they tell what works and what didn't, you just get sent home.
Photo Archive
Building: Built - Fury '06R1 ...now on with the mods
posted on 11/5/15 at 10:04 AM
...I'm actually starting to wonder if the issue is gearchanges without the clutch which causes the exhaust to flame as you change
up...
It might not help but I doubt it, as you have been excluded for noise before you had that gearbox.
true enough. I can't really figure out a 'safe' way to run an exhaust to the back of the car which doesn't pass close to the
wheel or has the possibility of setting fire to the fibreglass.
Photo Archive
posted on 11/5/15 at 01:41 PM
...or short shift...
Some (possibly) more helpful questions...
Is it all the exhaust or is the BOV contributing? Only car I've ever seen thrown out at Blyton was his dump valve causing it.
If you've no room for a heat shield, could you wrap the exhaust under the arch?
With the side exit would a deflector angled towards the floor or under the body help? When I was black flagged at Zolder, I jury rigged one from a
coke can and that worked untill I melted the can; I've made a stainless one since.
