Davegtst
posted on 15/8/15 at 12:26 PM |
Extending air con condenser pipes
Somehow I need to get my a/c pipes extended on a 2002 MR2. It needed a new a/c condenser and they seem to be nearly impossible to get hold of and
very expensive. I took a punt and bought a US spec one as the picture seemed to look the same. Unfortunately it's like a mirror image and the
pipes are at the wrong end. Is there a way of extending the pipes maybe by using flexible rubber hoses that anyone knows about.
posted on 15/8/15 at 01:24 PM |
I'm sure I've seen a Eurocarparts catalogue for AC spares that possibly listed pipes and fittings?
blakep82
posted on 15/8/15 at 01:28 PM |
All the parts can be sold by car builder solutions, including rubber hoses, so I'd say yes
http://www.carbuildersolutions.com/uk/search?q=Air+conditioning
________________________
theconrodkid
posted on 15/8/15 at 01:40 PM |
them pipes are pretty thick so i assume the pressure is pretty high.
i would go to a hydraulics place and get them to make some up for you,maybe there is a reason they are ally and not rubber ?.
who cares who wins
pass the pork pies
Davegtst
posted on 15/8/15 at 02:10 PM |
It doesn't look like car builder solutions do the right type of fittings. I will need to go from aluminium to rubber then back to aluminium
for it to work. I've found this site in America that has quite a lot of different fittings that might work. I'm currently thinking of
cutting the pipe then using weld on barbs for rubber hose. Any idea how much pressure the condenser and pipework is under?
http://www.oreillyauto.com/site/c/search/A!s!C+Fittings+%26+Tu
bing/N0275/C0352.oap
posted on 15/8/15 at 02:40 PM |
Pressure is likely to be around about 5 or 6 bar
mark chandler
High side, 250-300 psi, compressor, condenser to evaporating valve, low side will see around 50psi
R134a is thin and will leach through rubber, you need the correct lined hose.
[Edited on 16/8/15 by mark chandler]
DW100
posted on 15/8/15 at 04:53 PM |
Condenser is usually on the high side, right after the pump.
Usual working pressure is 10-15 BAR.
Pipes can be really expensive and it may be cheaper to just buy the right condenser.
Have a look for a air con specialist near you that has facilities to make to pipe (or modify) as a swagging tool will cost around £1000 to make the
high pressure joins.
Ben_Copeland
posted on 16/8/15 at 06:04 AM |
There loads of 2nd hand aircon pumps on eBay. Would it not of been easier just to buy one of them?
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Davegtst
posted on 16/8/15 at 11:22 AM |
If only it was the pump. Unfortunately it's the condenser (radiator) that's leaking which for some strange reason are very hard to get
hold of.
Ben_Copeland
posted on 16/8/15 at 12:58 PM |
hold of.
Ah yes. Sorry miss read. I'll do some searching
Ben
Roadster
mark chandler
posted on 16/8/15 at 03:39 PM |
Could you recover the fittings or brackets from the old rad and TIG into the new one?
Davegtst
posted on 18/8/15 at 07:31 PM |
Not sure if that's possible. This is what I'm up against.
![](http://i156.photobucket.com/albums/t23/dave317/20150818_143800_zpsnqwawxps.jpg)
