Author: Subject: whats it called ? bolt problem
steve m
posted on 23/8/15 at 03:36 PM Reply With Quote
hi
Im after two 10mm thread bolts, but not with a standard 10mm head (17mm spanner size) but more like 13mm spanner size
with a built into the head washer
I know there out there, as my old starter motor used to be held in with a pair of bolts like this
steve
posted on 23/8/15 at 03:40 PM Reply With Quote
Fords tend to use them for starter motor and bell housings depending on the length you need. May be able to help ?
posted on 23/8/15 at 03:42 PM Reply With Quote
How long? They are oem bolts so the line can use the same assembly tool around different bolts..
Ive got some here I think as I keep all the fasteners off everything I dismantle
gaz_gaz
posted on 23/8/15 at 03:44 PM Reply With Quote
Sounds like you're after flange bolts?
steve m
posted on 23/8/15 at 04:14 PM Reply With Quote
Thanks Guys, just ebayed, flange bolts and that's the animal !!
steve
DapperRob
posted on 24/8/15 at 02:08 PM Reply With Quote
One of my favourite words.... FLANGE.
Smoking Frog
posted on 24/8/15 at 09:32 PM Reply With Quote
Reminded me of a sign I saw today, on the back of a windscreen repair van "Show us your crack".
hearbear
posted on 25/8/15 at 10:15 PM Reply With Quote
Did manage to get any of the bolts if not I have 3 in my van with m10 bi hex heads I could send no probs.
3.9Ltr SSC Stylus should be fun
steve m
posted on 26/8/15 at 07:52 AM Reply With Quote
I did, thanks, off ebay
steve
