Author: Subject: What's it worth. Exhaust Gas Analyzer
Irony
posted on 15/10/15 at 06:28 PM Reply With Quote
This has come my way from a local business that is shutting up shop. No idea what its worth. Any ideas?
HowardB
posted on 15/10/15 at 06:47 PM Reply With Quote
lend it out to the LCB massive,...
good karma in exchange
Howard
steve m
posted on 15/10/15 at 06:50 PM Reply With Quote
^^^ too right, as many an IVA newbie has failed on emissions
I would imagine any kit car friendly garage would want this kit
Irony
posted on 15/10/15 at 06:59 PM Reply With Quote
I have no problem with keeping it and lending it to anyone who wants to use it from LCB. Its quite big though so 'local pickup only'.
If someone did want to borrow it I might ask for a completely refundable deposit.
Irony
posted on 15/10/15 at 07:05 PM Reply With Quote
Ooooops forgot to post a picture
joneh
posted on 15/10/15 at 08:22 PM Reply With Quote
Can it be towed behind a VW for real life testing?
PorkChop
posted on 15/10/15 at 09:55 PM Reply With Quote
When was it last calibrated? I've worked quite a lot with various bits of analytical kit, without some idea of calibration it'll be less use than a chocolate teapot for figuring out if you can rely on the readings you'll see.
A calibration is not something you'll likely be able to do at home either, purely due to the gases you'll need.
owelly
posted on 15/10/15 at 11:13 PM Reply With Quote
I use response test gasses to check analysers and meters at work but you'll still need to calibrate the machine.
http://www.ppcmag.co.uk
russbost
posted on 16/10/15 at 09:26 AM Reply With Quote
Would have thought you could get a calibration sufficiently accurate to know whether something is a definite pass or a definite fail simply by comparing with results taken from known cars compared to that given by the last MoT. After all you'd never want to set something so that it is "just about" a pass
Irony
posted on 16/10/15 at 11:24 AM Reply With Quote
Apparently it was in use the day before the business closed so it must be fairly accurate. There must be a way to calibrate them.
Theshed
posted on 16/10/15 at 12:28 PM Reply With Quote
I had one once and the instructions told me how to calibrate against air in the atmosphere - with its known percentages of co and co2 etc
Clearly two test points would be better.
