Author: Subject: peugeut 306 brake light problem
steve m
posted on 25/3/16 at 03:38 PM Reply With Quote
Hi
Any one able to help?
Mums pug 306 2000, model, that's shes owned since 2000
None of the brake lights work, although all the bulbs are fine
The fuse (from the handbook) is good, as it powers the reversing lights as well, and they work fine
that's assuming we have the correct manual
with ign on, and head in the drivers footwell, and brake pedal pushed, there is a relay clicking, but I cant find were it is ?
also, were is the brake light switch
any idea's or any one have a Haynes manual they can scan and send the relevant pages to me
steve
Benzine
posted on 25/3/16 at 04:23 PM Reply With Quote
I had the same fault and it was the brake light switch. Slightly awkward to get to, it's in the dash around the steering column area, I got to it by taking off the right hand air vent, as well as reaching up from below.
rash12
posted on 25/3/16 at 05:08 PM Reply With Quote
MAY HELP ?
2000 306 HDi today. Remove the plastic fuse box cover. Remove the convoluted air pipe. Remove the 4 nuts that hold the steering column and lower it as far as it will go. Sit in the seat (ie you dont have to be laying in the footwell upside down) put your hand in above the column and up through the hole, the switch is to the right, (RH drive car) pull the wire and the switch will come out of the ho
le in the bracket. Afrter plugging a new switch into the loom, push the switch throught the hole, turn on the ignition, keep pushing the switch in (it clicks every time it goes in further) until the brake lights go off. Press one more click. Bolt in column, replace air pipe and fuse box cover. Hard the first time, 20 minutes after you have done it
steve m
posted on 25/3/16 at 05:53 PM Reply With Quote
Thanks guys,
funny thing is I had just googled it, and got the same post as above
steve
