Slimy38
posted on 10/12/16 at 12:58 PM |
Headlight washer check valves
My new Saab has been dumping it's screenwash, and it would appear the t-piece check valve is no longer a T (it's more of an L with a hole
where the second pipe should be!).
I've ordered a replacement but I've just noticed it says windscreen rather than headlight. Have I ordered wrong or will it be OK? Are
headlight washer check valves the same as windscreen ones?
posted on 10/12/16 at 01:59 PM |
Head lamp wash tubing is usually bigger bore than screen washers.
Slimy38
posted on 10/12/16 at 04:04 PM |
P00p, yes it is. Thinking about it the headlight wash tube is about 10mm bore, far bigger than the aquarium-like tubing for screen wash.
Thanks BT, hopefully I can cancel the order before it gets shipped.
