Trigger1
posted on 4/3/17 at 07:33 PM |
919 Blade Engine/gearbox builder advice
Can anyone recommend a decent and reasonably priced engine builder for a 919 engine? A gearbox rebuild is needed on a 919 blade.
I know of A B Performance but was wondering if there are any other known specialists that people use?
phelpsa
posted on 5/3/17 at 08:31 AM |
Try Big Cc in Wokingham. Not too far and have worked on every bike motor under the sun. I've had an engine build and a gearbox rebuild, both
with absolutely no issues and good value for money. Busa engine will be going back there in the winter.
mark chandler
posted on 5/3/17 at 09:23 AM |
If you can get a decent second hand gearbox it only takes 3 hours to spilt the casing and swap the shafts over, it's amazingly easy just nuts
and bolts.
Trigger1
posted on 5/3/17 at 10:03 AM |
and bolts.
'If' I can find one seems to be the problem. Many people say they are ok and then when you say you are putting it in a kit car they change
their comment!
mark chandler
posted on 5/3/17 at 12:35 PM |
The gearbox is designed to take the power and torque of the engine, the application may be harder as you cannot run a bike at full power for more than
a few seconds but you cannot escape the design parameters.
Provided you change gear cleanly they are fine.
My car with a turbo ramps out a lot more power than standard, I broke the box on a clumsy downshift ... Thi is more lightly the cause, same applies on
the bike nudging the gears up without a clutch is fine backed off the power not the other way although people do it!
Matt21
posted on 5/3/17 at 06:20 PM |
I have a stack of bits in the shed from stripped down 919's, I have a feeling I've already sold the gearbox internals, but I'll
double check tomorrow for you.
Instagram: @matt211988
Photobucket
My YouTube
Trigger1
posted on 5/3/17 at 10:49 PM |
Thanks, let me know if you do ![](/images//smilies/smile.gif)
ReMan
posted on 7/3/17 at 02:22 PM |
and bolts.
Ditto its an easy enough job with no special tools, quite satisfying too.
Difficult thing is getting a decent set 2nd hand, so you might have more than 1 go at it, but the cost of all new parts ( and pro fitting ) must be
prohibitive and time to swap/upgrade the engine
www.plusnine.co.uk
