PSpirine
posted on 9/7/17 at 07:35 PM |
What bit for roofing bolt??
Hi guys, can do with some help!
I'm removing an old garage roof tomorrow (asbestos corrugated type) before I get rid of the garage as part of a house refurb.
The roof and garage is mostly held together with large round "roofing" screws which are approx 18mm-20mm head diameter, M6 thread. but
they are cross slotted (i.e. X slot but completely flat, no point in the middle as per philips or pozi).
This sort of thing:
http://wickes.scene7.com/is/image/travisperkins/largeNormal/Roofing-Bolts-Wickes-Mushroom-Head-Roofing-Bolt-M6x30mm-Pack-18~C7322_510826_00?defaultIma
ge=travisperkins/missing-product
I'm using a cordless driver to remove them. Is there a large "flat X" driver bit for these, as using a PH4 bit doesn't give
enough bite due to the taper on the bit, and using a slotted flat bit results in a lot of skipping out of the slot?
Thanks!
[Edited on 9/7/17 by PSpirine]
jacko
posted on 9/7/17 at 07:59 PM |
You will be better undoing the nut and holding the head with a large screwdriver
or drill the heads off with a 6mm bit
jacko
SteveWalker
posted on 9/7/17 at 08:14 PM |
Large flat bit - I have actually used an inch-wide scraper (engine block not decorating type) ground flat for this when renewing the wood on my
trailer. It is easier though to cut off the nut end with an angle grinder or if they are through reasonably strong metal supports, the quickest and
easiest way is with a hammer and cold-chisel.
PSpirine
posted on 9/7/17 at 08:16 PM |
Thanks guys
It's not a nut on the other end, it's a folded metal bracket that's been threaded. Cutting it seems to be even more effort!
Will keep persevering with my flathead driver but will keep an angle grinder nearby
gremlin1234
posted on 9/7/17 at 08:31 PM |
quote: Originally posted by PSpirine
Thanks guys
coins are good tools for this, though you may want to file a flat edge on them.
from a health point of view, careful with the angle grinder, unless the material is truly soaked through its the worst thing you can do to asbestos
cement roofing
edit sp
edit 2, though you might just use the grinder on the bracket, still be careful though ;-)
[Edited on 9/7/17 by gremlin1234]
jacko
posted on 9/7/17 at 08:53 PM |
Drill the bolt head off thats the quickest and easiest way 6mm drill bit
Mash
posted on 9/7/17 at 09:18 PM |
Thanks guys
cement roofing
edit sp
its the worst thing you can do to asbestos cement roofing
x 2. Be VERY careful, and definitely wear a mask.
myke pocock
posted on 9/7/17 at 09:19 PM |
When I did mine I simply used an angry grinder with cutting disc to remove them. You arent going to reuse so why faff on. By the way, if you intend to
dispose of the asbestos sheeting at your local tip you know about the need to double wrap in thick plastic sheet and tape them up securely? At least
that is what I had to do.
PSpirine
posted on 9/7/17 at 09:56 PM |
Thanks, yes aware of asbestos double bagging for the local tip - the roof panels are being removed very carefully, and with a dust mask, although they
don't seem particularly "dusty/crumbly".
I'm not reusing the bolts (the asbestos roof is being discarded) but the rest of the garage is being collected tomorrow evening (for a princely
sum of £3.20 on ebay, just saves me having to dispose of it and the buyer is dismantling it).
I just want to get the roof off as I don't want any H&S "liabilities" with him having at it or taking the panels away.
Will avoid angry grinding anything unless I properly bugger up a bolt head manually in which case I'll saw/grind through it.
Quite surprised nobody makes a bit/driver head to suit those bolts... or rather who thought it was a good idea to make bolts like that!
redturner
posted on 10/7/17 at 07:10 AM |
There are tools like that. Have you tried the Dutz fastener tool.....
rgrs
posted on 10/7/17 at 11:00 AM |
I have always used a pair of bolt croppers to cut the bolts, causes minimal disruption and it's quick.
We then always use an asbestos collection service, they turn up load all the sheets and issue the disposal paperwork, normally costs about £10 a
sheet.
If you work out your costs double bagging and transporting it's not normally worth it doing it yourself.
Roger
SJ
posted on 10/7/17 at 01:08 PM |
I have always used a pair of bolt croppers to cut the bolts, causes minimal disruption and it's quick. We then always use an asbestos collection
service, they turn up load all the sheets and issue the disposal paperwork, normally costs about £10 a sheet. If you work out your costs double
bagging and transporting it's not normally worth it doing it yourself. Roger
I did this. Bolt croppers are perfect for the job.
Mine cost about £240 to get the sheets from a single garage roof taken away by an authorised contractor. Having said that they seemed very blase about
handling the sheets.
Stu
