posted on 17/9/17 at 12:17 PM |
Position of Brake Proportioning Valve / Hydraulic Handbrake
Is there a preferred place to put a brake proportioning valve in the rear brake line when also using a hydraulic handbrake?
Before the hydraulic HB? After it? Doesn't matter?
It's Evolution Baby!
adithorp
posted on 17/9/17 at 12:34 PM |
I'd say valve then h/brake so the valve doesn't reduce the pressure from the h/brake.
Hydraulic hand brake won't pass IVA though (or MOT) and I'm not sure how proportioning valves are treated.
http://jpsc.org.uk/forum/
posted on 17/9/17 at 06:26 PM |
Cheers Adi. No MOT / IVA worries.
voucht
posted on 18/9/17 at 10:59 AM |
Check this document, pages 27 to 33. I did these 3D drawings myself for this French company which is specialized in hydraulic systems for racing
cars.
There's a lot of different installation 3D drawings according to the configuration of your braking system, and you'll find your answer
there.
https://www.exactfrance.com/pdf-cata/cata2015_chap5.pdf
Hope that will help
Cheers.
Sylvain
https://vouchtroadster.blogspot.com/
https://cafrazx550.blogspot.com/
Angel Acevedo
posted on 18/9/17 at 04:23 PM |
Late to the party, but, I would put the H/B last to have the least amount of connectors therefore less chance of leak/failure as H/B serves (on some
cars) double duty as Emergency brake.
posted on 18/9/17 at 05:20 PM |
Thanks guys
