po79
| posted on 9/9/18 at 06:33 PM |
Alhambra/Galaxy heater control panel issue
Hi all,
I cant get my head around this issue.
The control panel on my 2001 Alhambra isn't working, the blower works but it's on a supersets circuit the the other controls ei A/C,
heater directional control, panel lights, air re circulation.
I've read that removing the panel unplugging it then turning the ignition on for a few minutes then off and re connecting with rest the panel
but this has not worked.
All the fuses have been checked with none found blown.
Does anyone know what the problem could be.
The rear heater isn't working either, could this be down to a relay if so anyone know which one?
I've one just brought the car as I was desperate for transport due to other problems.
Poe.
| posted on 10/9/18 at 10:52 AM |
Got rid of a similar age Alhambra a couple of years back. I'd start by checking the connections to the panel to make sure they're all OK.
Whilst it may not have blown a fuse if there's a poor connection somewhere the panel controls may not function correctly.
From memory the different parts of the Alhambra/Galaxy/Sharan dashboard aren't that difficult to dismantle. Just go slowly so you don't
snap any plastic tangs that hold it together. Older plastic does go brittle and can break more easily. That said there's so many of those cars
around that most parts are still available for them.
