scotlad
posted on 20/6/20 at 09:13 AM |
Locost brake master cylinder issues.
Morning folks
i was fitting rear pads to the rear brakes on BobC's old locost yesterday. Its nice wee Wilwood callipers on the back and i was using a g clamp
to push back the piston on the nearside, with the reservoir cap off. There was a fair bit of resistance, followed by an audible pop on the other side
of the car near the front, upon which the caliper piston retracted quite happily. I've now discovered that the brake pedal now has no resistance
and will happily flap about with one finger. I'm guessing that i've blew a seal in the master cylinder due to the back pressure somehow.
Does this sound about right?
I've added a couple of photos of the master cylinder arrangement fitted on the car to my photo gallery. Can any of you knowledgeable souls
suggest where it might have come from/ what type it is so i can see about a replacement. Alas Bob C hasnt been on here for ages or id ask him
myself!
Graham
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
40inches
posted on 20/6/20 at 09:36 AM |
Not seen a vertically mounter MC before on a locost!
[Edited on 20-6-20 by 40inches]
scotlad
posted on 20/6/20 at 09:48 AM |
Thanks for adding the photos 😊
Yeah not sure why Bob did it like this 😟🤔
Myke 2463
posted on 20/6/20 at 10:16 AM |
Original Mini had vertical master cylinder
Be Lucky Mike.
posted on 20/6/20 at 10:27 AM |
Sounds like you let air into the system by tillting a caliper piston just bleed it and should will be fine.
You should never need a excessive force to push the caliper pistons back that makes me think your brake pedal isn't allowing the the master
cyilder piston to come full back. However any force you exert with a G clamp is nowhere near the the presure in the system during an emmergency stop.
gremlin1234
posted on 20/6/20 at 10:32 AM |
if its a dual circuit master, I would expect the pedal to still work on the single remaining circuit, ie at least some pedal pressure to work the
front brakes.
can you take some photos of the pedal assembly
scotlad
posted on 20/6/20 at 11:15 AM |
Bled everything again but pedal still flapping. Have cleaned side of MC up and got number 3212 474C which appears to be, as suggested above, an
original BL mini master cylinder, so I'll hopefully be in luck if it is fooked 👍
posted on 20/6/20 at 11:27 AM |
Forcing the pistons back may well have caused the master cylinder to fail , it’s a common problem on Vauxhall’s , better to release the bleed nipple
with a hose attached before pushing the pistons in. If the master cylinder has failed I would remove it and look for any identifying marks or take it
to your local friendly motor factors and have a word with an older member of staff that doesn’t rely on a computer or registration number. It’s been a
while since I saw a cylinder like that one but have a vague memory of Metro’s using a similar item ? It is also possible to dismantle the cylinder and
get part numbers off the seals , again your local motor factors might help ? Past Parts in Bury st Edmunds have reconditioned obsolete master
cylinders for me in the past, in one case saving me £500 plus VAT
scotlad
posted on 20/6/20 at 11:35 AM |
I've checked online and visually similar ones around 60 quid, plus I did spot a repair kit for £12 on eBay which may do. Hey ho you live and
learn....
