Replicar328
posted on 12/5/21 at 06:16 PM |
Using plywood to attach grp body
With the help of Martin Batho I've discovered that my BMW328 replica bodywork fits a standard Locost chassis. Such a great discovery, I thought
I'd have to design my own chassis from scratch. But how to attach the body to the chassis? My thinking is that plywood panels screwed to the
tubular frame would work - for example one sheet attached behind the seats, rising up to meet the bodywork, and two perpendicular sheets to the back
would locate the whole rear end firmly. I could probably weld on some kind of lightweight skeleton to achieve the same, but I prefer the plywood
(marine ply?) approach which is easier to do and is more within my skill set.
Does anyone have experience of doing similar, and would the IVA inspectors accept this to be safe?
Adrian
Mr Whippy
posted on 12/5/21 at 06:56 PM |
I suggest looking at home built boats using grp skinned ply construction. Nothing wrong with wood used in the structure if used correctly. The JBA
Falcon I built had wooden sills covered in GRP along with various ply bonded in to the structure to stiffen it up.
I'd definitely only use Lloyd's approved marine grade ply. It's not all that expensive and I buy mine from Robbins Timber. It comes
stamped with the Lloyd mark, the Robbins Elite is the type I use, perfect for a car.
Replicar328
posted on 12/5/21 at 07:14 PM |
Many thanks, some really good advice. And it looks like Robbins Timber can advise on suitable adhesives. No doubt more costly than B&Q plywood,
but worth doing it right
Slimy38
posted on 12/5/21 at 08:14 PM |
Consider the original Locust car as well, that was a wooden bodied seven. Do a search for a build diary or two?
gremlin1234
posted on 13/5/21 at 06:14 PM |
nothing wrong with ply in car construction, in many ways it can be viewed as 'resin bonded wood', or even 'wood reinforced
plastic'.
if you look at the regulations, there is virtually nothing saying about materials used, apart from they must be suitable.
the MOT regs refer to corrosion, not specifically rust etc and can include wet or dry rot, or even woodworm!
you won't even need marine ply, since its unlikely to need the continuous salt water submersion capability. (unless you are building an amphicar
also since these will not be structural panels, you have even more freedom.
SJ
posted on 14/5/21 at 09:12 AM |
Use epoxy resin and glassfibre to skin the ply. Epoxy can also be used for bonding - East Coast fibreglass are great for this stuff.
Replicar328
posted on 15/5/21 at 10:01 AM |
Thanks everyone, all good inputs. I'm feeling a lot more confident about using plywood now
Adrian
