mcerd1
| posted on 19/9/22 at 06:45 PM |
cheap AC compressor replacement ?
My tin-tops had a bit of a rattle for a while thats been getting gradually worse - I was hoping it'd just be a heat shield, but no luck
when I finally got a proper chance to get underneath it turns out its the AC compressor - rattling like a bag of spanners
so while I've 'solved' the issue for now (by taking the belt off) I'd rather sort it properly - but I'm finding prices
anywhere from £150 to over £400
or I seem to be able to get scrapyard units at £25-£40 (its a 1.8 duratec in a C-max)
AC is one area I've never dealt with before now and I don't want to be messing about with unreliable aftermarket rubbish parts
(I've got my brother offering to do the empty / refill at his work for free - but I won't get more than a couple of go's at it)
and the car isn't worth enough to spend top dollar on new genuine parts...
so any recommendations on brands / where to buy / any other tips & tricks?
mark chandler
| posted on 19/9/22 at 09:04 PM |
I dropped a second hand (factory original) one on my car years ago and it’s been fine, I did drain all the old oil out the system including flushing
it through, same for the new/old pump and it’s been fine - it will need a new dryer.
If it’s clanking you will need to do this whatever pump you put in.
ReMan
| posted on 20/9/22 at 12:01 AM |
Its often the clutch that rattles not the pump itself
Assuming its still working. And its likely you can remove, check, lube, replace this without disconnecting the gas side
www.plusnine.co.uk
coyoteboy
| posted on 20/9/22 at 11:32 AM |
This. It was my plan until I left it so long the pump grenades from the heat input too.
https://www.fixmystreet.com/
| posted on 20/9/22 at 02:53 PM |
Tin top AC's a bugger. Great when it's working, but always seems to be £££ to fix when it develops a fault. Plus having to pay people with
the right kit and skills to empty/re-charge it with gas.
On my last car (VW Passat) it thankfully never developed a fault. A re-gas every 5-6 years seemed to keep it running good a icy cold.
I'd be hesitant to fit a scrapyard sourced AC unit for my own distrust of it's longevity and potentially having to payout again to re-fix.
